| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Say in a 2 Way Design....
When the Woofer Cone is Moving Alot how does it still manage to Clearly Produce the Midrange? |
#2 |
It does until you start getting sensitive to doppler and intermodulation distortion. It places an upper limit to power output that tends to force a lot of people to be interested in 3-ways. You can use a larger diameter woofer, of course, but then you have to listen to that.
#3 |
One of the reasons why 2.5 ways and MTMs are handy as they reduce the excursion.
No longer DIY active |
#4 |
Because it still driven with voltage containing midrange. Since the woofer not saturated yet, Mid and Low-Mid frequency still able to clearly produced.
#5 | |
Also.....if you have a Dual Voice Coil Woofer.....will it have a Negative Effect if you send Bass to one Coil and Midrange to the other Coil? |
#6 |
Speakerholic
In the simplest of terms, it only moves a large distance for the lowest frequencies and while it is doing that it is also moving back and forth a small amount for the mids and highs during those large excursions. I hope I'm not making this too simple but the easy way to see it for yourself is to put your right hand in the shape of a gun, sideways in front of you as if you are shooting someone to your left and begin to wiggle your index finger back and forth rapidly. While you are doing that, move your whole hand fore and aft (toward your body, them away). This is what happens in a speaker. The large fore and aft being the bass and the finger wiggle is the mids.
The question about the woofer, I don't know. Why would you consider doing that? It's kinda like using summer tires for snow isn't it? A woofer is a woofer. if it is capable and you want it to carry mids, you want both coils doing that, no? |
#7 |
The question about the woofer, I don't know. Why would you consider doing that? It's kinda like using summer tires for snow isn'toofer. if it is capable and you want it to carry mids, you want both coils doing that, no?[/QUOTE]
Just an Idea Cal....its a diffrent Version of what im doing now Two Similar Woofers in the Same Cabinent....one connected to a full Range amp and the other Connected to a Higher Power Sub Amp. |
#8 | |
Did it Himself
The different bands to different coils idea is a non-starter I'm afraid and could lead to damage to the amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#9 |
Speakerholic
Yes, I saw that. I see nothing wrong with that at all. Maybe because I've done something similar more than once. Yes I did have the cabinet divided so it's really more like a .1 way
#10 |
That trick is commonly pulled with just an added low pass network on the second (or third, etc.) woofer. It's sort of a Band Aid though, you still have a woofer playing midrange, or maybe you just can it and use one running mids, or a midrange altogether. Ceases to be a 2-way long ago.
| Why is the tweeter above the midrange/ woofer? | chuck55 | Multi-Way | 26 | 28th November 2009 11:50 PM |
| Bandpass Woofer/Midrange? | m@ | Multi-Way | 5 | 25th March 2006 02:10 AM |
| Mid-woofer as midrange ? | foo | Multi-Way | 6 | 10th January 2005 12:01 AM |
| Audiom Woofer and Midrange | GeorgeBoles | Multi-Way | 7 | 22nd September 2004 12:50 AM |
| Page generated in 0.09931 seconds (79.05% PHP - 20.95% MySQL) with 11 queries |
