Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th April 2010, 08:07 AM   #1
Default LED VU meter question
Hello!
I just ordered a few LM3916 IC's that I intend to use to build a LED audio meter. My plan is to connect it to a stereo I've built using TDA7240 amp IC's (20W).
My approach is pretty straight forward, I'm planning to use the typical application schematic out of the spec sheet, which you can see here:
http://www.national.com/images/pf/LM3916/00797101.pdf
The full spec sheet is here:
http://www.national.com/ds/LM/LM3916.pdf
The typical application design is for a 0V to 10V VU meter. The amp supply signal is from my mp3 player. So it seems clear to me that I don't hook the signal from the mp3 player directly into the LM3916 IC, as it's nowhere near 10V. So is the signal source I put into the LM3916 simply the speaker output from the amp? The IC's are cheap, but I'd prefer not to burn any of them up if I don't have to...
Thanks!
-Chad
Old 6th April 2010, 10:11 AM   #2
sivan_and's Avatar
Send a message via Yahoo to sivan_and
add a preset at the input to set the level..the final LED should be red colour should come on when the amp clips !!!!
SivanandBalan
Old 8th April 2010, 07:36 AM   #3
National gives good front end circuits for these. Search for its applications on their site.
Old 14th April 2010, 11:29 AM   #4
col is offline col  Australia
col's Avatar
I have been looking into this a bit too. A couple of interesting links:
LED Audio VU Meter
http://www.ozitronics.com/images/k89.jpg
http://www.ozitronics.com/docs/k89.pdf
I actually don't want the full meter though and would prefer a clipping light, to do this accurately seems to be a bit more complex.
I'm wondering if it would be possible to use the LM3915 with one multi-color LED.
col.
http://www.minirig.org.au
Help with LM3915 LED VU meter Youran Digital Source 4 20th September 2009 09:47 AM
LED VU meter neil_kaye Parts 8 27th December 2006 07:43 AM
LED VU meter for ZV9 neil_kaye Pass Labs 1 21st December 2006 06:58 PM
Single LED VU-Meter-like indicator felix42 Solid State 8 2nd August 2006 01:44 PM
led vu meter leander Solid State 3 22nd September 2005 03:06 PM
Page generated in 0.08676 seconds (59.71% PHP - 40.29% MySQL) with 10 queries
