Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 2nd April 2010, 05:40 PM   #1
Default Stacking Mosfets for ClassAB Amplifier
Guys,
My first post and thanks for any input.
I guess I wanted to hear some thoughts on things I need to think about when stacking P or N Mosfets (to get to higher voltages) for a ClassAB amplifier. Is a resistor divider from the rails good enough? What about charging the Gates for the top and bottom Fets.
Circuit of Interest:
Also pros/cons on using a complementary output stage vs. a cascode output stage (just using N-Types), especially if I wanted to get an output around 500V.
Yes, I know there is no need to stack the Fets in the attached JPEG since they can easily do more than 80V.
This is just for my personal education.
Eric
Old 2nd April 2010, 07:57 PM   #2
star882 is offline star882  United States
star882's Avatar
IGBTs are commonly available up to 1.2kV. It is better to use single devices than it is to build a cascode if the objective is high voltage.
But if you use a low voltage MOSFET to emitter/source switch a high voltage MOSFET or bipolar, you can accelerate switching speeds by counteracting Miller capacitance.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 2nd April 2010, 08:14 PM   #3
Were you talking about 500v p to p if so there are some 600w P chanel mosfets
like the IZTR16P60P available at Digikey.
Old 2nd April 2010, 10:19 PM   #4
Woody, I have looked at those and they seem like a good choice for my design.
My real question pertains to the correct way to stack the Fets (both the two P's and the 2 N's), if I wanted to go greater than 600V, say 1000V.
1. What are good values for the resistors going from the rails and why?
2. What sort of compensation should I add for this circuit, specifically for the top and bottom Fets?
Thanks again,
Eric
Old 3rd April 2010, 11:38 PM   #5
star882's Avatar
The correct answer is to special order high voltage IGBTs. It is not very easy to ensure voltage sharing with series semiconductors.
1.7kV, 20A IGBTs are just over $5 each, although it will very likely get quite expensive as you'll probably go through a lot of them before you have a working design. IXGH10N170 Ixys IGBT Transistors
Old 5th April 2010, 04:45 PM   #6
Thanks Star. I will look into these.
But I guess I still don't have an answer on to properly stack mosfets for higher voltages...purely for my own education and not necessarily for this circuit.
-Eric
help about power amplifier mosfets milad-k800 Car Audio 1 23rd August 2008 09:26 PM
Ultrafast NoCap-ClassAB MikeB Solid State 94 23rd July 2007 05:56 PM
DIGITAL amp or ClassAB to drive a bass only speaker? AndrewT Solid State 1 12th August 2006 01:26 PM
Lynx amplifier using Mosfets Dusk Solid State 7 16th July 2005 11:26 PM
simple amplifier with mosfets Stormo Solid State 15 20th March 2004 02:30 AM
Page generated in 0.08528 seconds (70.07% PHP - 29.93% MySQL) with 10 queries
