| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi everybody.
I'm posting to get some advice, or perhaps to be pointed in the right direction. The backstory: some friends of mine had their Mackie 408M mixing console blown by a surge when the venue's sound man hooked it up to a generator which was malfunctioning. They didn't have time to mess around with repairing a twelve-or-so year old mixer, so they bought a new one. They were going to throw the broken one out, but I told them I'd like to take it and try to fix it, and they then said I could have it. They're on the road right now, so I haven't had a chance to open up and look at the unit. My question is this: before I ask them to drag it all the way back here, is there a chance that it is fixable? I realize that this could depend on a whole lot of variables. I'm just wondering if it's possible that the unit is salvageable, and if so, if I would have to invest very much into fixing it? If it is salvageable, any tutorial suggestions or hints as to what I'd have to read up on would be greatly appreciated too. Thanks |
#2 |
Sure it's repairable! First, pop the cover and look for burned parts. Power supply is the first place to look. Get a diagram so you aren't working blind. These are not complex devices, at least considering what the problem here is.
#3 |
I see that a 408m is a powered mixer.
The mixer section is likely to survive as it would be regulated. The power amplifier could be another story altogether
#4 |
It's surely worth a look to fix it. Generators can overvoltage to the point where IC's short, filter capacitors fail and leak etc. hopefully just the fuse went. If it's 12 years old it will be pretty durable.
#5 |
All we really know is that it was on generator power, and it no longer works. Did it receive 150v? 800v? Reversed neutral and ground or something? We have no idea, consequently we have no idea what is wrong with it. We have to find out.
Isolate the problem. If it is "dead" as in no signs of life, then start with power supply. Is the main power supply even getting mains voltage? You could have a burnt out inrush limiting thermistor or something or a dead varistor somewhere. Oops, no inrush part on the 408. I agree the power amps are the most suspect. Try disconnecting them. And contact Mackie at Loud Technologies and request the schematic set for your mixer. |
#6 |
Thanks a lot for the replies!
When I get my hands on it, I'll open it up and see what story the power supply tells and move on from there. And get in touch with Mackie, too. Thanks again for the advice |
| Mixing console faders. | argonrepublic | Instruments and Amps | 3 | 19th June 2005 05:50 PM |
| mixing console bus bar | argonrepublic | Parts | 5 | 7th June 2005 04:17 PM |
| Strange problem with mixing console | Pierre | Class D | 4 | 1st June 2005 09:14 AM |
| Mixing console upgrade with carlosfm | donnie7 | Parts | 43 | 19th April 2005 08:32 PM |
| Page generated in 0.09058 seconds (73.37% PHP - 26.63% MySQL) with 10 queries |
