| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
diyAudio Moderator Emeritus
Currently the mains in my house does not have a safety earth (Until not so long ago Dutch houses only had them in bathrooms and kitchens.)
So will something like a balanced power supply actually have advantages? I can imagine that having my dac, phono preamp and linestage etc. all attached to the same psuedo earth will prevent possible ground loop problems. In my case I could just omit the center tap to safety earth connection? Last edited by Bas Horneman; 26th March 2010 at 01:45 PM. |
#2 |
Magneto the Gravity Man
Something like this was tried a year or 2 ago by Ray on the humungous CD 63 / 67 thread.
It's now on his website. Balanced Power Source Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
Surprising a ground was not required just a few years back. I assume the utility has grounded the supply at the transformer, but just not required bonds at your panel? I can't imagine the enclosure of your panel is actually floating. Is it tied to neutral (if one is provided)?
A shielded isolation transformer is really all you should need, but I would definitely try to find a way to give yourself a grounded secondary. Maybe grab a tap off your water service or something. I'm not convinced on the need for balanced power when the transformers you connect it to are not balanced. I prefer the grounded neutral / hot method and finding the high capacitance lead on each downstream power transformer I use. That lead connects to the neutral. I have an AC drive feeding my well pump. It spits out copious amounts of noise. Until I used a C-core power transformer for my D/A, I never had any noise issues. Split bobbin or shielded were sufficient. Once I installed the shielded transformer (1500 VA for the entire system), all was silent as could be. Maybe someday I'll swap out the C-core. Technically, balanced power is not permitted in a US residence. Next comes many posts with 'hang the code' and 'I've been doing it for years' |
#4 |
#5 |
It is, but split 240V is not the subject here. Bas has generated 120V single phase with the midtap grounded (60-0-60). The desire is to plug either DIY or commercial products into this supply. These products are designed for 120V operation and have either 2 or 3 wire plugs, typically polarized.
NEC Section 647 specifically addresses this application. Requirement #1: "The system is installed only in commercial or industrial occupancies." There are many other requirements that I suspect no DIY'er has bothered to follow. Just ground the center tap and away you go. |
#6 |
This has worked well in the past as the mains are balanced at the 240 volt lines.
What the other guy said----Standing on the shoulders of giants. New avatar- no more little array |
#7 |
Note: The two circuit breakers in the above 240V input schematic need to be interlocked.
Kevin |
#8 | |
I couldn't actually say if this has advantages over the standard system as there is the Powerplant already doing it's own clean up of the mains
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#9 |
Hi
I'm not sure about in the US but in the UK having an isolation transformer in this manner gets around the "Code" as its an isolated supply. I think the same would be true in the US as if it were'nt the code would apply to high voltage supplies in tube amps etc these can be up to 1500Vdc. Ben Duncan has a compendium of articles entitled "high quality mains audio supplies" which extols the virtues of the balanced supply. Dam |
#10 |
Most power inverters are balanced output since it simplifies the design.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
| How to build a nice power supply | jackinnj | Chip Amps | 6 | 6th July 2008 03:59 PM |
| i want to build a power supply! 12volt dc | michelevit | Power Supplies | 3 | 6th January 2006 05:00 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Build a Power supply For amp. | Dj BASS AMP | Car Audio | 3 | 24th May 2004 04:23 AM |
| Balanced linestage power supply and main board. | Tony D. | Swap Meet | 1 | 14th October 2002 04:48 PM |
| Page generated in 0.14300 seconds (71.52% PHP - 28.48% MySQL) with 11 queries |
