Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th March 2010, 04:51 PM   #1
Norfox is offline Norfox  United States
Default In-line attenuator for headphones (wiring)?
This is really simple for you people. I am trying to put an attenuator between my computer and the powered stereo speakers, so I don't have to go into the desktop to control the volume. I purchased an attenuator (calrad #25-396)(10k dual audio, 1/4 watt, 20% tolerance). 3 wires in and 3 wires out, 6 connections. I do not have a wiring diagram. Please help!
Old 18th March 2010, 05:33 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Potentiometers (Beginners' Guide to Pots)
Not 3 in/3 out, but two channels
Hope that helps...
Jim J.
Old 18th March 2010, 05:47 PM   #3
Default It does help.
Thanks again.
Old 18th March 2010, 08:03 PM   #4
Default I don't know what I'm doing.
This is a picture of what I'm working with. Can someone put it in layman's terms?
Old 18th March 2010, 08:30 PM   #5
Speedskater's Avatar
It's a dual or stereo pot (Potentiometer). Or see fig.6 from above post, then it's a Dual-gang volume control.
Kevin
Old 18th March 2010, 08:48 PM   #6
Okay, that helps too, but the posts that I am soldering to are not numbered. The diagram is still confusing.
Old 19th March 2010, 02:38 PM   #7
So, we have two pots on a common control shaft.
The input signal is connected to the 2 end posts.
The output signal is connected to the center post and to the end post that the ground/neutral/shield wire is connected to.
The odds are 50/50 that the rotation will be backwards.
If so than swap end posts.
Kevin
Need Help please . Headphones into line up of tube amp . benoit26 Tubes / Valves 9 28th August 2007 05:05 PM
Headphones output to line level Simpleton Parts 1 13th May 2007 09:54 PM
DIY Fidelity attenuator wiring - help please tfowler Class D 10 3rd December 2006 05:33 PM
Line Level / Headphones M.Joshi Everything Else 5 21st December 2004 05:32 PM
Page generated in 0.12280 seconds (49.61% PHP - 50.39% MySQL) with 11 queries
