| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Like any other here, I have a number of resistors, capacitors, chips... etc... and sometimes i buy some parts without purpose, because i dont know that I already have it. I think that some local php/sql database will be nice for better organization, and spending some time.
Anyone already use that? Thanks ![]() Boggy |
#2 |
Did it Himself
I had exactly the same problem so created a simple spreadsheet list of part numbers, quantities and supplier order codes.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
I have Farnell, Digikey prices and ord. numbers for some parts, max voltage for caps, max power for resistors, package (SMD/TH)... etc... |
#4 |
Did it Himself
I have upto 3 suppliers listed for some parts. Currently running 5 worksheets with over 100 lines on a couple of them. Just keep things in order and use the sort and filter tools and works fine for me
#5 |
Banned
Should be straightforward to knock up a database in either MSSQL or MySQL and access it using ASP or php.
I don't think you really need the relational database facilities though, a flat file will probably be adequate. You could import your spreadsheet into SQL or even MS Access if you just want to run SQL queries against it. I often run queries in SQL Enterprise Manager. You can get a desktop version of MSSQL (free) and install IIS on your local HD from the Windows install disk if you go the ASP route. w |
| electronic parts - equivalent database? | Amrita | Parts | 0 | 6th October 2009 10:40 AM |
| electronic parts | joe.b | Parts | 1 | 15th December 2008 01:39 AM |
| Electronic Parts | smjohnson63 | Swap Meet | 5 | 1st February 2008 03:51 AM |
| where can I buy electronic parts? | 52remi4ever | Vendor's Bazaar | 0 | 19th February 2007 07:08 PM |
| Page generated in 0.08020 seconds (71.35% PHP - 28.65% MySQL) with 10 queries |
