| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#31 |
When you suggest to capacitively couple the coil I take it you mean by winding one coil directly over the other? Can you explain your comment above "that capacitively coupling will obtain the same results". I think that if a decent size transformer (VA rating) is used it should be able to handle a 555 at full output. You are probably right that a short duration pulse is a good logical place to start for a project like this then experiment later once things are working.
moray james |
#32 |
By capacitive coupling i only meant using a capacitor to couple the 555 output to the coil.
#33 | |
Hi analog_sa,
The first was my function generator. With this equipment, the frequency change with temperature. Even if Schumann resonance is 7.83Hz +/- 0.5 Hz, you can hear difference when varying the frequency from 0.01 Hz. For an accurate frequency, I use an old CD player where I burn a continuous 7.83Hz sine wave. For the antenna, I put a 10mH inductor (from my stock) with a 600 ohm serial resistor onto the analog output. I plan to build a generator with microcontroller, more friendly than CD player. Correct me if I'm wrong, but the 555 is not able to provide a signal with 50% duty cycle. It generates 7.83 HZ with other high frequency. Last edited by Eric Juaneda; 6th March 2010 at 05:17 PM. |
#34 |
These two site have lots of info on the 555 device. What size of area coverage do you get using the single 10mH coil? I will look forward to any and all micro controlled designs that may spring from this thread as I said that type of design is beyond my skills in electronics. I would be useful to have a device with multiple frequency settings and perhaps even various wave form settings. Thanks for the input Eric.
555 Timer/Oscillator Tutorial 555 timer
moray james |
#35 | |
Some designs definitely use a 555. Acoustic Revive, otoh, do not. Just reversed their circuit (from pics in the review) and will draw and up it tomorrow if laziness does not prevail. The 8 pin device seen on the pics turned out to be a dual opamp. First half works as a relaxation oscillator and the second as a bandpass filter in order to turn the square waves into something prettier. A low pass should be equally effective. Split power is derived from the incoming 12v dc from two zeners and a virtual ground, so effective PS is probably +-4.7v. It seems AR gets better reviews than simple square wave generators so a sine wave is probably better. The pcb seems quite nice but component cost is way below $10 with the PS. Add a pcb and a case and total manufacturing cost is still under $40. No idea how much advertising and net buzz cost but they seem to operate on a pretty healthy markup. |
#36 |
Why am I reminded of the orgone box?
#37 | |
Hello Moray,
- external diameter 44mm - height 21mm. |
#38 | |
Hi analog_sa,
.In this schematic, the oscillation frequency can vary with the value of the power supply and temperature. |
#39 |
Forgive me I was not clear in asking my question. I was wondering what size of radiating area that you have found your device to have? How far physically can you be away from the device and still perceive its impact?
moray james |
#40 |
Here is the AR circuit. Some component values can be seen from the published pics but all should be easy to calculate as these are standard textbook curcuits. Opamp has a fet input and needs to have a low voltage offset. Output waveform is a modified square wave.
| Resonator guitars | PhaseLockLoopy | Instruments and Amps | 3 | 30th May 2008 04:28 PM |
| Cabinet brace act as helmholtz resonator? | RyanW | Multi-Way | 17 | 2nd October 2007 11:08 PM |
| Horn-Resonator? | TroelsM | Multi-Way | 5 | 29th September 2005 02:23 PM |
| isobaric resonator? | tade | Subwoofers | 6 | 17th August 2005 07:24 AM |
| Ceramic resonator pinout | trwh | Digital Source | 2 | 21st July 2002 12:35 PM |
