Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 25th February 2010, 06:53 PM   #1
slopps is offline slopps  United States
Default DIY Question: t-amp to single driver
I'm building a very simple all-inclusive single speaker using a t-amp. Since I can't bridge the connection since the t-amp is already bridged, is it okay to just plug the single speaker into the right channel?
I'm worried that songs utilizing left/right speaker effects will essentially be cut in half and you won't be able to hear what was supposed to be played on the left speaker. Is this an issue, or no?
thanks a lot in advance!
Old 25th February 2010, 07:15 PM   #2
Bone is offline Bone  United Kingdom
You can certainly do that but as you realise any left stereo information will be lost. What you should do is to combine both L & R channels before you connect them to the amplifier.
What is the source you are using as that will determine how you connect the two channels together?
Old 25th February 2010, 07:20 PM   #3
I'm using a Sonic Impact T-amp to connect to a single Fostex full-range driver.
The source is going to end up being an ipod (I'm building a small i-pod dock)
I had planned on bridging the amp channels but I've since read that you can't bridge t-amps. Is that true? I definitely don't want to break anything.
Old 25th February 2010, 07:52 PM   #4
planet10's Avatar
A t-amp is already bridged internally.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th February 2010, 08:24 PM   #5
right, I know they're already bridged internally, so does that mean plugging a single driver into the left channel (for example), that the driver will be receiving the full stereo information for both left and right speakers or it will only be getting the audio for the left speaker only?
Old 25th February 2010, 10:35 PM   #6
Speedskater's Avatar
Sum the Left and Right audio channels into mono before the input to the T-amp.
Kevin
Old 25th February 2010, 10:45 PM   #7
Ok cool, thank you.
I was gonna house all of this in one unit...amp and speaker all together so it could just be a portable little ipod listening station.
Is there an easy/small chip or something that I can do this with? or is there just some plug adapter for it?
I searched for downmixers but I can't seem to find anything.
Old 25th February 2010, 10:47 PM   #8
I think something like this might work?
Parts-Express.com:1/4" Mono Jack To 3.5mm Mono Plug Adapter | adaptor 3.5mm 1/4" plug 1/4" jack headphone adaptor stereo jack 1/4 jack
Old 25th February 2010, 11:18 PM   #9
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
I wouldn't try using both channels without more research. I assume you are thinking of running the two channels in parallel? Evidently T-amps don't like to have their output - terminals connected. There has been plenty of discussion about this over at Audio Circle, specifically how to connect early Red Wine amps to a subwoofer plate amp that sums the grounds. Of course, you may as well try a single channel first. If it provides enough power, then you needn't mess with two.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 25th February 2010, 11:22 PM   #10
I'm not concerned about the power, it should have plenty for such a small setup
I just want to be sure the full signal is going to go to that one driver and not just the left channel. Know what I mean?
I'm thinking about songs that utilize panning from speaker to speaker, like putting the drums on the left speaker and the vocals+guitar on the right, etc etc. I want to be sure this single driver is gonna get both channels sound signal combined.
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 03:48 AM
Small single driver speaker suggestion (and power rating question) percy Full Range 68 17th March 2005 07:04 AM
First DIY Single-Full-Range-Driver Help Needed GregGC Full Range 19 24th February 2004 07:13 PM
Single Driver question AudioGeek Full Range 3 28th January 2004 02:23 AM
Fostex single-driver noob question here... GrahamnDodder Multi-Way 17 5th July 2003 12:15 AM
Page generated in 0.11247 seconds (78.21% PHP - 21.79% MySQL) with 10 queries
