Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 25th February 2010, 11:53 PM   #11
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
I got ya'. Somehow the stereo/mono issue didn't even occur to me. I'm a little loopy while I recover from a good hard run. I'll be better after this coffee. I don't know that you will find a single stereo>mono adapter. You could use a combination of Y-adapters, first a 1/8" / 3.5mm (not 1/4", btw, you are looking for "mini plugs" with your Ipod) to either two RCA's or mono 1/8", then maybe you could find a splitter that would combine the two RCA's or mono 1/8" into a single mono 1/8". Personally, I'd just put a 1/8" (3.5mm) stereo jack on your enclosure, and use a regular ol' 1/8" stereo cable. Then, sum the channels in the enclosure when you connect it to the amp. If you are using the pre-existing T-amp enclosure, it would be quick work to open up the case and connect the L&R (tip and ring) segments of the jack. Either way, it is cheaper than buying an adapter, and less of a PITA.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 03:48 AM
Small single driver speaker suggestion (and power rating question) percy Full Range 68 17th March 2005 07:04 AM
First DIY Single-Full-Range-Driver Help Needed GregGC Full Range 19 24th February 2004 07:13 PM
Single Driver question AudioGeek Full Range 3 28th January 2004 02:23 AM
Fostex single-driver noob question here... GrahamnDodder Multi-Way 17 5th July 2003 12:15 AM
Page generated in 0.08526 seconds (64.86% PHP - 35.14% MySQL) with 10 queries
