| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
i was wondering if anyone has done anything with making a crude drilling macheine. basically to drill holes for DIP ICs, resistors, ect... but not necessarily odd spacings like gainclone chips.
in any case, for this i would like a precision movement, 0.1", controlled electronically. i wanted possibly to make the thing computer controlled, though i guess i could settle for a manual interface.
if only it could be used for good, not evil... |
#2 | |
se |
#3 |
well, i wanted a faster method. i figured if i could program the board into memory, then i could just put in the bit, drill, press a button, drill, press a button, drill, ect... and this kinda idea of sensors also instrests me. but i don't know what to do for precise measurements of distance. i am thinking i may just use metal brushes to complete a circut and tell the computer where the drill is over the moving board assembly which will use a slow movement from a simple motor. a refererance hole could be made first in the corners so everything looks neat in the end.
ok, this sounds good, sure i'll need more help later.
#4 | |||
Just draw your layout on the grid paper from the start, slap it on the board and start drilling. Quote:
By the way, are you going to be drilling these boards before or after you've etched them? If you're doing it after, then you should already have reference holes to work with and should just be able to start drilling. Quote:
se |
#5 |
well, i was just thinking for common circuts (like regualtor circuts and others) could be automatically drilled out. i was thinking if it's not expensive, why try to eyeball the locations of the holes, why not just program the holes into the computer and let it drill for you.
#6 |
Chris your talking CNC here and to design a numerical controller and software is beyond this forum
#7 |
to do it by hand, you can use a molex 0.100 male header -- the pins are spaced at the exact interval, just tap it with a hammer and voila you have a template of holes spaced at o.100 inches. this is what I used to do for IC holes. I now have gotten practiced enough that I can set a pilot hole with a small carbide bit by hand.
you can also buy a grizzly mini-mill for about $500, for another $500 you can outfit it for CNC including software. there are at least two Home CNC groups on Yahoo. Once you make the investment you can use the CNC machine to route PCB's. |
#8 |
I photo-etch my boards at home using datak materials. I use a simple CAD program to do the layout. The pads I etch have a small hole in the middle of them which captures the drill bit so it drills in the center of the hole. Very quick and easy, I do the drilling by hand using carbide drill bits and a dremel moto tool.
No precision motion needed. Sheldon |
#9 |
hmm. well i'm just an ee student. i kinda like analog. not that music is the only time analog is applicable, but there are definate analog pricipals in audio. so i got started in audio. i also liket he idea of computer controled stuff and for control systems. so this seems to be an ideal and practical project.
#10 |
That's a great project, don't let me disuade you. I just wanted you to know if you want dip holes, there's other ways. A CNC router, diller would be really useful for lots of projects. Not cheap though.
For motorized slides, you may want to check with velemex (sp?) they are fairly cheap and work pretty well. They are no newport, but they don't cost what a honda civic costs either. Sheldon |
| Precision Devices 12" woofers | Defo | Multi-Way | 8 | 30th July 2009 01:05 AM |
| 30" long 4" Precision Port | PoorboyMike | Subwoofers | 4 | 11th May 2007 12:01 PM |
| Compact 15" sub - BMS or Precision Devices? | DIAR | Subwoofers | 7 | 4th January 2007 04:06 PM |
| PRP - Precision "Metal Film" Resistors | Gooch | Parts | 4 | 8th March 2006 09:30 PM |
| FS - Precision Port 4" | cbecker33 | Swap Meet | 2 | 3rd May 2005 03:25 PM |
| Page generated in 0.13440 seconds (73.15% PHP - 26.85% MySQL) with 11 queries |
