| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Well, after looking over some (quite a few) threads, and reading all sorts of claims of how LED's (i.e. high-brightness blue ones) affect the sound when the power for them is taken from the rails, i decided to find a sensible solution:
well, one was additional transformer/additional winding for a transformer which peter employs .. but i don't feel like breaking the potting of my toroid, and i don't have space for another small transformer .. so ... batteries came to mind, 9V specifically well, i had no 9V batteries lying around, so i picked up a 1.5V (AA? .. or AAA? in any case, A of a sort!) and the LED doesn't work (not enough voltage) .. two of them work though no diodes needed, no resistors (in my case, the led is bright but doesn't light up the room .. although it IS still light outside, so i may need to re-evaluate that decision when the sun sets) needed .. and i have a bright red LED on my gainclone supply w/o it effecting the sound at all btw, for this to work, you can't use a spst switch .. dpst/dpdt is required so that the LED lights up when you press the switch |
#2 |
oh yeah .. the thread title should be "... adversely affect the sound"
i think .. that sounds right |
#3 |
as a birthday candle held near your preamp.
#4 |
well the birthday candle will eminate some heat, which will warm up your preamp more so at the spot you're holding the candle at, and therefore totally throw off the sound!
especially if you're leaning towards left/right channel and less towards the other |
#5 |
hmm, i often lean to the left and right at the same time...
any info on the current draw with 2 AA batteries?
if only it could be used for good, not evil... |
#6 |
no clue, sorry ..
the LED's are rated 20mA .. now I've seen one light up at 20mA .. and um, then i fried it shortly thereafter it seems its about 1/2-2/3 of its brightness .. and its getting to be pretty dark as the sun is starting to set .. although i'll be able to tell when its fully dark in about 2-3 hours .. |
#7 | |
You could probably get away with a bit of additional resistance (i.e. a resistor) and prolong the battery life. se |
#8 |
well the setup i did with the 2AA batteries is just a temporary one to test and see if it works, and if it does, how well
when it runs out i'm going to use a 9V battery, and DEFINITELY a resistor .. probably around 1k should cut it and still be plenty bright .. |
#9 | |
se |
#10 |
As someone with absolutely no interest in LEDs (or birthday candles) i wonder why don't you just put a few turns of wire on top of your toroid and get the led supplied from there.
| Would this tear in the driver affect sound? (pic inside) | wixy | Multi-Way | 1 | 6th January 2007 07:41 AM |
| Will routing edges of front baffle affect sound? | Ken C | Multi-Way | 12 | 3rd December 2004 08:57 AM |
| Can a power cord affect sound quality?? | sully | Parts | 103 | 13th November 2003 02:23 PM |
| does the resistor's ppm affect the sound? | mekanoplastik | Parts | 9 | 4th June 2003 04:21 AM |
| Page generated in 0.15086 seconds (53.23% PHP - 46.77% MySQL) with 11 queries |
