| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
hi all,
besides the hobby on this site i also do some silversmithing. i purchased a micromotor (similar to what dentists use) and i use this for both polishing and stone setting. its this machine: link however i think i broke it yesterday as i was polishing up a piece i just finished. the speed control simply stopped working and the device operates at full speed only no matter if i use the foot pedal or the potentiometer on the front to adjust the speed. i'm going to make a go at repairing this, but just in case that the device can't be repaired, it seems relatively easy to build a mosfet pwm motor control. this motor is 32volt and max 80w which makes me believe that its not too coomplicated to replace the controller with a generic design? anypne built a circuit like this before? anything i should watch out for? the one thing im not sure how to design is a current limiter to stop the current if the motor gets overloaded. any ideas? thanks! par Last edited by parb; 16th February 2010 at 12:49 PM. |
#2 |
Be careful as some motors especially coreless ones don't like pulsed supplies. I expect the controller is a linear one and the series transistor has gone short. All you probably need to do is to replace it and possibly the driver transistor. The circuit is normally quite simple.
#3 |
the more i've been thinking about this the more i'm sure its just the power transistor that has gone short. not sure if its a mosfet or not, but this seems likely.
| sub repair...need help ! | artie in miami | Subwoofers | 1 | 10th April 2009 05:55 PM |
| Speaker repair | patknk939 | Multi-Way | 17 | 16th February 2008 09:44 AM |
| Page generated in 0.07015 seconds (67.74% PHP - 32.26% MySQL) with 10 queries |
