Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 12th February 2010, 02:29 AM   #1
johnr66 is offline johnr66  United States
Default Getting only the "common" signal
I know I can take the difference of the left and right channels (L-R) to produce a quasi rear channel. The sum of L and R to get a center channel or mono sound. The problem is, if there is a signal in only L or R channel it still appears quite strong in the mono (L+R) channel. It is fine and quite normal, but lets say I want to diminish output to the center channel unless the signal is common to both channels, how can I do this? I'm guessing some sort of multiplier, So 2L*0R = 0C, or 2L*2R=4C
This is not a home theater project, but listening to only the L, R, L-R or L*R lets me here instruments or vocals that were covered by the louder vocals or instruments.
Old 12th February 2010, 08:13 AM   #2
godfrey is offline godfrey  South Africa
I'm pretty sure it's not possible to extract only the common signal.
btw - multiplication will give pure distortion e.g. piano * trumpet = nasty mess
Old 12th February 2010, 10:55 PM   #3
star882 is offline star882  United States
star882's Avatar
Take the FFT and look at what's common to both?
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 12th February 2010, 11:39 PM   #4
This has been something I have thought about doing for
years without getting to a good conceptual answer. The
FFT analysis might work but I'm not sophisticated enough
to judge that possibility.
My basic notion is that you would have vastly improved
image stability, potentially more accurate as well, with
a true center only (common) signal. Two speakers, near
left and right, with the standard stereo signals, and far
left and right channels with the left and right only signals.
I'd love to hear that.
I have never heard nor seen a mathematical description
of the trifield method of synthesizing multiple channels from
a stereo signal. I have heard it done on Meridian systems and
it's impressive. Jim Bongiorno sells a box that creates three
channels, I believe on the same or similar principles. Let's
hope this thread brings some approaches to light along
those lines.
Skip
Old 13th February 2010, 11:50 AM   #5
Steerpike's Avatar
It can only be done digitally. Done, I believe, by means of autocorrelation.
The later Dolby Pro-Logic decoders did this to extract the dialogue channel
(I have a Yamaha DSP1000 that does this - that part of it is quite effective, but overall it is not a pleasant sounding piece of machinery)
Once you have the common signal, you can subtract it by analogue means from the matrixed Left channel and matrixed Right channel signals to get a more-left-than-left and more-right-than-right.
Steerpike's Toybox
Old 13th February 2010, 09:40 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
L, R, L+R and L-R are all you can do passively, AFAIK
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 13th February 2010, 10:42 PM   #7
What if you were to do:
"Common Channel" = L - (L-R)
Doing L-R should leave you with the material which exists only in the left channel. Subtracting that from the left channel should give you only the material which is common to both channels.
I can't see why it wouldn't work, but it seems too obvious to have been overlooked. What am I missing?
Old 13th February 2010, 10:53 PM   #8
Steerpike's Avatar
Originally Posted by theseekerr View Post
what if you were to do:
"common channel" = l - (l-r)
l - (l-r) = + r
Steerpike's Toybox
Old 14th February 2010, 01:56 AM   #9
I can see that algebraically, but I'm having trouble with it logically. Shall have to break out Audacity and prove it to myself, I guess....
Old 14th February 2010, 05:29 AM   #10
Talking Heads "Once In A Lifetime (stereo difference)"
is this what you're trying to do
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
"A standard CD player outputs signal at 24V" wwenze Digital Source 16 13th July 2009 04:50 PM
which common large FR offer good vocal "reproduction"? freddi Full Range 0 23rd July 2007 12:36 AM
"Signal Lock" Indicator for CS8412/TDA1543 Nisbeth Digital Source 7 5th January 2004 09:02 PM
Page generated in 0.10511 seconds (77.42% PHP - 22.58% MySQL) with 10 queries
