Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 5th June 2003, 02:14 AM   #1
jimbuto is offline jimbuto  United States
Send a message via AIM to jimbuto
Default I'm probably retarded, but...
5{ reason if I hooked up my vcrs (two of em) to a DJ style mixer I couldn't get the video to come through the output (which would go to a monitor of some sort)? Would I be able to crossfade the video that way? Once again, I am probably retarded.
Old 5th June 2003, 12:40 PM   #2
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Default yikes!
There is a world of issues in mixing video signals. Sync alignment, time base correction....
Easiest way to tackle the challenge is using something like this:
http://www.videoguys.com/datavid.htm#se200
Old 5th June 2003, 01:27 PM   #3
MikeW is offline MikeW  United States
MikeW's Avatar
The mixer probably has a low pass filter. Video goes up to 4.2 Mhz. audio only 20khz..
MikeW
Old 5th June 2003, 03:28 PM   #4
Thanks for the info! I guess if I want to play with this more its going to require a bit more effort than slapping some RCA plug into my mixer
Old 6th June 2003, 01:48 AM   #5
PassFan is offline PassFan  United States
Why don't you try it and see what it does, you might be surprised.
Old 6th June 2003, 07:18 PM   #6
Wouldn't blow my mixer would it?
Old 6th June 2003, 11:07 PM   #7
Default Don't bother...
I don't think it will blow up your mixer, but it for sure won't work as a cross fader or anything else. The signal coming out of your VCR is up in the megHz. Its unlikely that the signal would get past the first component in the mixer.
Basic fader stuff for home video is not expensive - less than $100. Most of it is old stuff since almost all of this stuff has now moved over to computer based, even for the home. If you have a decent computer, you can do some neat tricks.
Old 7th June 2003, 12:15 AM   #8
Cool, I'll keep an eye out. Thanks all!
Old 7th June 2003, 01:52 AM   #9
I don't think there's a whole lot to a DJ mixer, is there? Aren't they just a few volume faders and a pan pot? Does your dj mixer plug in and if so, what for? If it's strictly passive a video signal is not going to hurt it.
Old 7th June 2003, 04:05 AM   #10
even if it did not blow it up, it would not work! How video and audio work are two different things. In sound, you lower the overall level and the sound goes down. The same is not true for TV. I am not going to try to explain it here - just look up how TV works on the web.
A DJ mixer is usually not passive. It has mic inputs and turntable inputs.. Both of which require amplification.
Need help!!!I’m retarded… Clarion wiring….. fredrow Car Audio 3 14th March 2009 09:52 AM
Help! my $#@'s gone retarded aa7679 Everything Else 1 10th February 2009 04:37 PM
Am I Retarded? Retsim_X The Lounge 6 13th December 2005 10:05 AM
Page generated in 0.09716 seconds (76.72% PHP - 23.28% MySQL) with 10 queries
