Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th January 2010, 08:57 PM   #1
nad is offline nad  United Kingdom
Default Do mains RCD's reduce dynamics?
Hello,
I'm wondering how much a simple and unavoidable mains circuit RCD reduces amplification dynamics?
I ask as I've recently had my house consumer unit replaced with a regulation dual RCD type which isn't a problem as it's unavoidable, but my system is in an outbuilding which has it's own RCD/MCB's running from the house consumer RCD/MCB's, so now my systems AC has to pass through 2 sets of RCD/MCB's.
Bit of a mouthfull I know, should I bypass the 'outbuilding' RCD?
Any opinions on RCD's??
Old 31st January 2010, 03:34 PM   #2
Speedskater's Avatar
For those of us who are in N.A. what are RCD and MCB?
My thought would be that RCD's are Ground Fault Current Interrupters.
That MCB's are circuit breakers?
But what is the real meaning?
Kevin
Old 31st January 2010, 03:58 PM   #3
Send a message via MSN to sq225917
You have guessed correctly..
hoping to pick up some things.
Old 1st February 2010, 08:59 PM   #4
oldphrt is offline oldphrt  England
Send a message via AIM to oldphrt
Originally Posted by nad View Post
Hello,
They don't affect dynamics and safety is important, so you may as well leave them in. Think about it, if you can run a 3kW electric kettle through an RCD without it dropping excess volts why would it have any trouble with the hundred or so watts of an amp?
It's audio mythology spread by the technically illiterate, forget about it.
Fred
Old 1st February 2010, 09:59 PM   #5
Now that I know what RCD's and MCB's are. Nether will affect the quality of your AC power. The RCD sensing circuit has no effect on more and the failure mode contacts have less effect than a wall plug. The MCB small resistance and contact have no effect also.
Kevin
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
Dynamics in Loudspeakers gedlee Multi-Way 181 8th October 2007 08:31 AM
Hammer Dynamics gchrist Multi-Way 7 6th March 2006 03:48 PM
breuer dynamics pamaz Analogue Source 17 7th April 2004 07:22 PM
Sony SACD dynamics PH104 Digital Source 0 4th January 2003 12:38 AM
Page generated in 0.09357 seconds (67.22% PHP - 32.78% MySQL) with 10 queries
