Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd January 2010, 02:58 AM   #11
infinia is offline infinia  United States
infinia's Avatar
Originally Posted by motbuddy View Post
so where should i clip my black wire of my probe to?
I had got some advice which ask me to use an isolating-transformer. But it seems like not possible for me to buy it.so what else can i do to have a look on the waveform at the primary side?
thank you.
If you cant get an isolation transformer (note for floating the DUT only) connect oscope gnd ONLY to earth. Otherwise STOP untill you get one or find out Y u need one. This thread is becoming a public hazard.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 22nd January 2010, 03:03 AM   #12
infinia's Avatar
Originally Posted by Juergen Knoop View Post
with only one isolation transformer, the scopes ground set other parts of the DUT to live where you don't expect it, which is not good too.
regards
Yes u are possibly changing the measurement but at least its not a safety hazard.
You are making a PE connection to the DUT circuit when ever u connect the probes common so what.
Old 22nd January 2010, 03:08 AM   #13
Juergen Knoop's Avatar
using two transformers is no safety hazard as the floating voltage is earthfree.
so what? You may set the case of the DUT to live. Touch it and prepare to be bitten.
regards
Old 22nd January 2010, 03:15 AM   #14
infinia's Avatar
i would like to upload a full schematic for the primary side.below is the attach.
Attachment 154904
Do u mean by measure the ripple in such way?
thank you.
No dont do this unless u have an isolation transformer (note u are only a diode away from the AC primary)
This thread is already become much too dangerous for this level of dialog!
Old 22nd January 2010, 03:22 AM   #15
infinia's Avatar
regards
This is Basic lab safety 101 ( I can't believe this JK I'm having this level of talking here)
Yes u are right but you should advise any persons entering the LAB that touching DUT items under measurement is potentially hazardous.
But most people expect the test equipment to be safe to point at and move dials and such.
Old 22nd January 2010, 03:22 AM   #16
godfrey is offline godfrey  South Africa
How about:
A) Forget the oscilloscope.
B) Use a multimeter to test DC and AC voltages between various points.
It's simple and safe.
p.s. and check the circuit - those diodes look wrong.
Old 22nd January 2010, 03:31 AM   #17
infinia's Avatar
Yes but even some multimeters are connected to the line with no isolation.
Use battery DVMs to be specific
Originally Posted by infinia View Post
Using O-scopes 2 channels for differential measurements is good advice. Using a battery powered DVM is the best advise for novices.
DIY build sound better than a good commercial design in a side-by-side comparison? smellygas Multi-Way 66 25th November 2009 08:26 PM
How to measure mains waveform safely? JoshK Tubes / Valves 11 11th May 2009 11:16 PM
My GC is up and running, side by side with P3A Jean Chip Amps 2 21st July 2004 10:38 AM
Side fire sub, how close can magnet be to side? tim_rule Multi-Way 2 2nd February 2003 08:22 PM
Page generated in 0.09531 seconds (75.75% PHP - 24.25% MySQL) with 11 queries
