| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
This sounds like a dumb question, but are the volume controls on audio amplifiers linear taper or log taper.
Doug |
#2 |
diyAudio Moderator Emeritus
Volume controls are in 99.9 % of the cases logarythmic types because human ears are not too linear.
In the case of an inverted Gainclone you'll see that ( because of that particular topology ) a linear type is used. The way it is used in that schematic causes "log-like" behaviour.
It's only audio |
#3 |
Thanks Jean-Paul;
Do I understand this right? A linear taper increases the volume in a linear fashion ie: 1/4 turn = 25% increase in volume, 1/2 turn = 50% increase in volume etc etc. A log taper will increase the volume level a lot more during the first 50% of travel, then during the next 50% of travel the volume level becomes less and less ( more compressed ) or is the other way around. What am I missing?? Doug |
#4 |
The progression of signal level is very slow at the start. Rate of change increases with clockwise rotation.
#5 |
Thanks John;
Hey, I was close, just had it backwards So, what do most amps have, log or linear? Build lots of speakers, but not amplifiers LOL Doug |
#6 | |
It's only audio |
#7 | |
shouldn't this apply to every amp that has negative feedback? |
#8 |
Thanks once again Jean-Paul
I am aware that the ear is a very non linear device ie: it dosent hear all frequencies equally well, especially at low volumes levels. The ears response flattens out as the overall volume level is increased. This is based on the equal loudness curves developed by Fletcher Munson. Attached is a link for those who are interrested. http://hyperphysics.phy-astr.gsu.edu...nd/eqloud.html Doug |
#9 | |
My son was in Toronto recently and has just discovered tube amps. He listens to headphones a lot and I have been thinking about getting him a kit amp for next Christmas for his first experience. It wont be the highest end amp, but wont be the lowest end either. Do any of you guys have any suggestions? Doug |
#10 | |
It's only audio |
| 24mm Carbon Potentiometers Linear 100K 100pcs | space-cake | Swap Meet | 0 | 22nd October 2008 05:10 PM |
| really weird linear potentiometers that have a logarithmic response | VvvvvV | Instruments and Amps | 8 | 30th March 2007 10:00 PM |
| potentiometers | zahlm | Parts | 1 | 15th April 2004 05:43 AM |
| Potentiometers | slogan2112 | Solid State | 2 | 19th December 2003 06:54 AM |
| Page generated in 0.11223 seconds (76.80% PHP - 23.20% MySQL) with 10 queries |
