Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th December 2009, 10:58 PM   #21
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
The source impedance is between 2 & 3 as is the load impedance. Ground is not a signal path with balanced lines. Often the lines have no relationship with ground, so there's no point in trying to measure one.
On another note, maximum power transfer occurs when Zs = ZL. There's nothing old or new about it, it's just a fact
Old 29th December 2009, 11:03 PM   #22
Key is offline Key  United States
Can someone else explain what I am talking about please? Because I am not even talking about voltage or power here I am talking about rejecting interference and I don't think dhaen is getting that.
Old 29th December 2009, 11:15 PM   #23
zigzagflux's Avatar
You are correct, the load impedance is between 2 and 3. This is not the issue of what makes a balanced system. If I float the signal on 2 and 3, and have no intentional connection to pin 1, the system is balanced because the impedance from pin 2-1 is infinite, and the impedance from pin 3-1 is infinite. The impedances from each signal pin to ground is the same (infinity), therefore the system is balanced. This helps with noise rejection when a differential/balanced input is used.
I can do the same thing but have each pin (2,3) connected to ground (pin 1) by means of 100k resistors. Same impedance to ground, therefore a balanced system.
If I tie one of my pins (say pin 3) to pin 1, I still get the same signal between pins 2 and 3, but I have now unbalanced my system because the impedance from 3-1 is now zero, and the impedance from 2-1 is not. Essentially I have a traditional RCA type cable, not a balanced cable, even though XLR plugs might be used.
My eureka moment was realizing voltage balance from signal to ground has nothing to do with being a balanced system, it's the impedance balance to ground that makes it balanced and gives me the benefits.
You were correct.
http://www.jensen-transformers.com/an/an003.pdf
Last edited by zigzagflux; 29th December 2009 at 11:17 PM. Reason: added Jensen link
Old 29th December 2009, 11:19 PM   #24
Thanks zizag!
I know nothing about electronics but I thought I was kinda sorta right on this one and just wanted someone who actually knew what they were talking about to step in lol. Thanks
WTB: Male Panel Mount XLR"s..... Minion Swap Meet 4 22nd December 2006 12:12 AM
WTB: BNC male connectors Jimmy154 Swap Meet 0 9th November 2005 03:11 PM
Why are XLR outputs male, and inputs female? Bricolo Parts 5 30th August 2004 01:43 AM
FS: Gold Neutric Male and Female Cable ends PHilgeman Swap Meet 0 7th January 2004 02:03 PM
XLR 4pin to 3 pin male adapter kevinhero Parts 3 18th November 2003 01:09 PM
Page generated in 0.08066 seconds (72.03% PHP - 27.97% MySQL) with 10 queries
