Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd September 2012, 10:47 AM   #11
DF96 is offline DF96  England
Some of the early low noise VHF transistors were quite fragile and could easily be damaged by static electricity or overload (including nearby lightning). Later devices were more robust. You could check DC voltages in the front end, but bear in mind that some of them may be signal-level dependent. Maybe you will be lucky and it will just be a bias resistor which has changed its value.
If you attempt to change anything in the VHF front end then you must put the replacement in exactly the same place, as stray capacitance can form a significant proportion of total capacitance. Even then some realignment may be needed.
An 'earth' connection could be either for an external turntable, or for AM reception with an external wire antenna. Not relevant for FM.
rotel ra 820 diymax62 Solid State 1 11th May 2009 12:05 PM
rotel 820 stan curtis lt cdr data Solid State 12 8th July 2007 05:26 PM
Rotel 820 schematics pete.a Solid State 9 16th January 2005 07:39 PM
Rotel 820 schematic's pete.a Everything Else 0 14th December 2004 04:20 PM
Fixing a Rotel 820 pete.a Solid State 0 12th December 2004 07:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
