Here's my new rack made out of sollid maple. Dimensions of 1 piece :64x4x3
I can sit on a cross (68kg) so my 25 kg Aleph5 isn't a problem
Ralph
Ralph
Banned
Joined 2002
Thats a nice rack! heh.
Could you please post a bit on construction and design considerations you made?
Also, what is that silver amp you have on the bottom? It looks really sweet and I'd like to have an idea about where/how you build the enclosure.
Those little Tivoli's are sweet, do you run it through your system?
Thanks and well done on the rack,
Bart.
Bart.
Bart,
originally I was inspired by the spider rack from
finite-elemente but I could find the extrusions like they use. I already had the classic tnt-flexy but it was to solid and I had to have good passive airflow for my power.
That is the silver box at the bottom, it is discribed in the following threadhttp://www.diyaudio.com/forums/showthread.php?s=&threadid=14544 , it an Alpeh5
I first designed it in 3dsmax:
you can also look at the avi:
film
and then made a scale model 1:1 out of spurs when that turned out fined I made one out of maple (strong hard but not brittle like oak)
I didn't use dome nuts because I like it simple and straight and my maple floor get major dented because of the weight.
Ralph
anf finallyAn externally hosted image should be here but it was not working when we last tested it.
film
Ralph
rwagter said:I didn't use dome nuts because I like it simple and straight and my maple floor get major dented because of the weight.
Fair enough
Maple is a great choice for this application, solid, strong, and pretty too - you did an excellent job, well done.
I need a new rack, and you have given me some good ideas, thanks
- General Interest
- Everything Else
- flexy cross; a new diy rack
