| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
When studying amp schematics, I often see a single resistor in the feedback path. This single value resistor must have a definite effect for a particular band of frequencies. Certain frequency may react differently when facing this resistor, some may pass thru some may not, is this assumption correct?
I need help to explain the what if questions in my head lately for example; A single resistor with a value of 220 in the feedback path replace by three different values resistors in parallel to get the same resultant overall value of 220 too (1k, 500 and 647). Or 1/220 = 1/1000 + 1/500 + 1/647 Will certain frequency within the band goes thru different resistors which correspond to the easiest path thru a particular value resistor? Would there be any advantage using multiple value resistors rather than a single resistor in the feedback path? I wonder what differences it may have with the sonic of the amprefier. Thanks in advance Chris |
#2 |
diyAudio Moderator Emeritus
Hi Chris,
The resistor(s) are not (ideally) frequency dependent. The frequency dependence will be provided by capacitance in the feedback circuit. So, for typical resistors, it will not matter how many series/parallel combinations you use, the effects will be the same as a single resistor of a value equal to the resistance of the combination. Rodd Yamashita |
#3 |
Thanks Rodd
| Calling amsci99 | YNWOAN | Analogue Source | 0 | 14th May 2008 11:35 AM |
| calling Yves.... | Nanook | Tubes / Valves | 10 | 1st June 2007 05:33 AM |
| Ireland Calling | Commited | Introductions | 3 | 2nd December 2003 10:43 AM |
| UK calling | Great Dane | Introductions | 1 | 16th October 2003 11:46 PM |
| Calling all Scandinavians!! | PeteMcK | Multi-Way | 9 | 19th July 2002 06:20 PM |
| Page generated in 0.07266 seconds (79.33% PHP - 20.67% MySQL) with 10 queries |
