Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Burn In speakercable
Old 6th January 2010, 10:15 AM   #1001
On Hiatus
SY's Avatar
http://www.qscaudio.com/support/libr...als/abxman.pdf
Page 10 has a nice and simple explanation of the statistics. 8 out of 10 would certainly satisfy me (and most other skeptics) that there's something going on. 9 or 10 out of 10 would get the trial publishable.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th January 2010, 11:37 AM   #1002
syn08 is offline syn08  Canada
Me too. Usually, such a result is good grounds for repeating the test.
Old 6th January 2010, 11:46 AM   #1003
Jakob2 is offline Jakob2  Germany
The phrase "about a 95% confidence level" is right as it means ~95% doesn´t it?
The "exact" number for 8 out of ten is 0.05468.... so that fits.
I don´t know what did happen during the calculation of the mentioned table, but would guess that they did calculate for a two sided test and forgot to mention it.
Together with the underlying phrase
"The table on this page lists a recommended range of trials, and the minimum number of correct responses
necessary to reach a 95% or better level of confidence."
the content of the table is wrong, as for example a 11 trial run gives p=0.113 for random guessing 8 or more correct answers.
It might be useful to do two sided tests (Leventhal had a paper on a topic
"statistical significant poor performance") but routinely it is a one sided test.
Wishes
Old 6th January 2010, 11:54 AM   #1004
On Hiatus
SY's Avatar
0.054 rounds down to 0.05. Close enough.
Old 6th January 2010, 12:19 PM   #1005
Normally the exact number would round to 0.055 and then......
I wouldn´t try to bring it down with rounding tricks, but as said before i´d be fine with 0.055 and report it that way.
Wishes
Old 6th January 2010, 01:39 PM   #1006
auplater is offline auplater  United States
auplater's Avatar
Default future test methods?
Since at least one "believer" has proposed all sorts of metallurgical, anisotropic micro-rheological like, and surface anisotropies, not to mention dielectric and insulative issues, with no corroborative evidence of any sort, , as probable causes for "burn in" and other cable differential behaviors, perhaps a Plackett-Burman type multi-factor design could yield some insight into the reality of said claims and beliefs and put them to rest
Not that I'd be interested in setting such an experiment up; , but it could provide an efficient screening methodology, assuming 2nd and higher order confounding has minimal effect. If not the case, there are other Hadamard matix type designs which significantly minimize trials and maximize results. The fly in the ointment is doing the up front work to design the tests properly.
A brief summary at the Wiki article:
Plackett–Burman design - Wikipedia, the free encyclopedia
"I've forgotten more than I care to remember" The Last Conspirators
Old 6th January 2010, 01:43 PM   #1007
On Hiatus
SY's Avatar
There's all sorts of interesting things to do IF the differences are shown to be audible. If not, who cares?
Old 8th January 2010, 04:42 PM   #1008
oatmeal769 is offline oatmeal769  United States
@ SY -
Without me having to go back and re-reading 20 pages again... Is there anything preventing a test-ee from making measurements and discerning a difference that way? - Essentially cheating by not using their listening skills alone?
I'm not as knowledgeable as you are regarding the ability to use instruments to 'measure' a burn-in difference. However, if you are sure that there is no measurable difference, I'm fine with it.
I do know that I have made measurements between components before which show a plainly obvious difference, even though no one could prove they heard anything.
Also, have we defined what will be used to listen? Is it music? Is it white / pink noise? Not that anything will make a difference, but again - unforeseen consequences.
Old 8th January 2010, 04:47 PM   #1009
On Hiatus
SY's Avatar
Honestly, I don't care if he can measure a difference or not. If there IS a difference, whether audible or measurable, that's really big news.
That said, I don't think there will be any measurable difference.
Old 8th January 2010, 04:47 PM   #1010
Pano is offline Pano  United States
Pano's Avatar
Hey Oatmeal - this thread had been quiet for over 24 hours. I thought SY had killed it off.
From my reading of the test, there is no reason the person being testing can not measure. It is not believed that the differences will be measurable. If they are, that's certainly interesting news.
EDIT. SY posted at the same time.
Take the Speaker Voltage Test!
Burn In speakercableHide this!Advertise here!
Why burn in? sianturi Multi-Way 17 1st January 2010 11:22 PM
burn in of components jitter Parts 25 30th April 2009 07:47 AM
Burn in on speakers Nordic Multi-Way 5 16th November 2006 10:13 AM
