Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 1st December 2009, 11:59 PM   #1
Send a message via Yahoo to BurkettC
Default HT Speaker wire in conduit
I have a question about speaker wires running through conduit. Several years back when I built my pseudo home theater, I installed EMT conduit in the walls at each speaker location so that I could change the speaker wires at a later date. When I did this, I had this little birdy in my head that said "speaker wires running through conduit might adversely affect the sound." I did it anyway.
Is there any appreciable affect of long runs through a metal tube? I wish I had just run plastic tubing for the conduit, but oh well. I suppose I could just do an A/B test on my own by laying wires on the floor to see if I can hear the difference... I will do this.... but just wondering if there is a consensus on this already.
Thanks!
- Colby
Old 2nd December 2009, 01:17 AM   #2
Speedskater's Avatar
With a modern well designed amplifier there should not be any difference. But some much older designs and some minimum parts count amplifiers could have problems.
Kevin
Old 2nd December 2009, 05:14 AM   #3
That's reassuring! I upgraded from a Yamaha HTR-5790 to a Denon AVR-5803 (got an insane deal on it) about a year ago, so I think both of them qualify as 'modern.'
Thanks for the response Speedskater!
Old 2nd December 2009, 10:15 AM   #4
pheonix358's Avatar
Is the conduit earthed, if not try it. It may help with long runs. Stops the long speaker leads from acting like antennae.
Terry
What we don't understand is called magic.
Old 10th December 2009, 09:21 PM   #5
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I'm just curious as to what would be affected that would make minimalistic amps have issues?
Jim J.
Old 12th December 2009, 07:00 PM   #6
Minimalistic amp designer omit the parts that keep the amp functioning in difficult circumstances. They seldom test their designs in anything but best case conditions. They often chose parts that are not good engineering decisions.
Kevin
Old 12th December 2009, 07:24 PM   #7
Glowbug's Avatar
I meant more along the lines of what would cause problems with the amplifiers, assuming the conduit wasn't overstuffed...
Jim J.
Old 12th December 2009, 08:17 PM   #8
It's an amplifier design problem. They removed (or used incorrect) parts that made the amplifier stable under a variety of load conditions.
Kevin
Old 15th December 2009, 11:24 PM   #9
dangus is offline dangus  Canada
Capacitance?
For peace of mind, connect a C-meter between the conduit and speaker cable. Calculate the impedance at audio frequencies, then stop worrying.
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
Heater wires through conduit mashaffer Tubes / Valves 5 7th January 2008 05:21 AM
Speaker wire ......... Why Madmike2 Multi-Way 697 4th August 2005 01:52 AM
Page generated in 0.09943 seconds (77.24% PHP - 22.76% MySQL) with 10 queries
