| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#21 |
i want 2kW motor which runs on 1.5 volt battery and weights 0.5 gram
did you see that? |
#22 |
oh, i forgot, it should run quietly
#23 |
Electrons are yellow and more is better!
I'm afraid I can't tell you right now. It's a multimillion dollar project and the application is very serious.
/Per-Anders (my first name) or P-A as my friends call me |
#24 | |
Edit: Perhaps this company is willing to design a motor according to your specs: http://www.magneticinnovations.com
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) Last edited by Edmond Stuart; 15th January 2010 at 04:17 PM. |
#26 |
You could try approaching a custom switched reluctance motor manufacturer with your application. These can have very high torque at low speed, but optimized speed/number of poles will have to be calculated with the volume of the resultant gear stack and maximum power output available for given motor configuration. This motor type doesn't have a wound rotor and so the IR heat can be drawn away easier with available fluid cooling.
#27 |
Proud Union Member
Does it have to be electric? There are some very strong compact hydraulic motors out there
| Is this box design strong enough ? | Bigun | Subwoofers | 2 | 27th February 2009 01:02 AM |
| Help! Strong hum from transformer | some1x | Pass Labs | 35 | 26th January 2008 08:32 AM |
| How strong does the box need to be? | wasted911 | Subwoofers | 60 | 14th January 2008 01:29 AM |
| 8x Mur 860 strong enough for 2 paralleled 4780? | Bassterror | Chip Amps | 4 | 8th February 2007 01:02 AM |
| Line out signal too strong | Mike Collard | Everything Else | 0 | 15th December 2001 06:47 PM |
| Page generated in 0.08712 seconds (77.15% PHP - 22.85% MySQL) with 10 queries |
