Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th November 2009, 04:09 PM   #21
thermal runaway's Avatar
Result , well done !
Old 11th January 2010, 03:01 AM   #22
trd1587 is offline trd1587  Canada
trd1587's Avatar
So how Much $ For that brand new TV repair job?
Old 11th January 2010, 04:41 AM   #23
keantoken's Avatar
Originally Posted by trd1587 View Post
If you are to play in electronics alot i Suggest you buy yourself a capacitor meter. You can find some under 100$ on ebay.
Regards....Marc
Don't need $100...
Electronic circuit schematic for capacitance meter, free on the Internet.
If you have a scope with a calibrator, you can check ESR:
Determine calibrator's output voltage and series resistance:
My Tek 561B calibrator has an output of .4V with 50 ohms series resistance... Since a reasonable capacitor's ESR will be below .2 ohms, we can assume the calibrator will see a dead short (this is fine, the calibrator is meant to be shorted to calibrate current probes).
So .4V/50=8mA
So now, let's connect a capacitor across the calibrator.
Look at the calibrator waveform on the scope when shorted with the cap - it will look like a triangle wave, except it will have big jumps where the trace changes direction. Measure the voltage of these jumps.
On a cap I measured a few hours ago, the jump measured 1.2mV.
So do the math with Ohm's Law:
1.2mV/8mA=.15 ohms
This was a 600uF 200V cap from a TV set from the 70's... (it was a good TV BTW, built like a tank. All that time, and the thing that killed it was NOT a bad cap...)
You can also calculate the capacitance by looking at the slope of the triangle wave, but I haven't looked up the math for that yet.
- keantoken
Greetings - New Member Checking In Moke Introductions 1 6th August 2008 02:51 PM
Checking ARC SP9 Pathmark Tubes / Valves 2 11th December 2007 05:03 PM
Checking in... ghudnub Introductions 1 19th September 2005 04:58 PM
Checking used capacitor chris ma Everything Else 7 24th June 2003 01:59 AM
Newbie checking in toenail Introductions 6 8th March 2003 02:15 PM
Page generated in 0.08128 seconds (67.64% PHP - 32.36% MySQL) with 10 queries
