Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 31st October 2009, 01:28 PM   #11
Mooly's Avatar
Will just add that capacitance meters DO NOT tell if a capacitor has developed a high E.S.R. which is the main failure mode in switchmode PSU/Inverters etc.
A good analogy is like reading a battery off load, any dry cell reads OK like that even if it's flat.
Old 31st October 2009, 02:10 PM   #12
Tripmaster's Avatar
Thanks Mooly, that's interesting
I've been building an amp this past week but I'll have another look at the SMPS this weekend. I am just a little concerned with regards to the bulb tester glowing brightly, and pulsing in time with the switching supply.
Richard
Richard
My photostream: http://www.flickr.com/photos/59839778@N04/
Old 31st October 2009, 02:16 PM   #13
Mooly's Avatar
Many SMPSU's are OK with a bulb but not all.
They need the full voltage applied correctly and quickly in order to self start. Some can latch (sometimes destructively) if the voltage is ramped up slowly.
I can't say either way on that without first hand experience of what you are working on.
A lot will depend on the current drawn from the rails on it.
Also many don't run properly with no load either.
Old 31st October 2009, 02:29 PM   #14
Tripmaster's Avatar
Thanks again
Richard
Old 31st October 2009, 02:37 PM   #15
Mooly's Avatar
Your welcome
Will just say that the majority of PSU problems (SMPSU) all come from capacitor failure... they are very highly stressed.
Unless you are used to working on them the best option is often just to replace ALL electroylitics... even the small ones as these too often fail.
You really need a fully isolated workshop so you can connect a scope across them and see what the ripple voltages are but PLEASE don't attempt that as the primary side is directly connected to the mains with no isolation.
Old 31st October 2009, 02:45 PM   #16
Tripmaster's Avatar
Your welcome
I purchased some of the smaller caps, 25uf from memory at the same time as 400v reservoir cap. When I connected the DMM (ohms) two or three of them didn't increase in value.
Richard
Old 31st October 2009, 05:42 PM   #17
Mooly's Avatar
It's not a valid test using a DVM like that... other than a short or nearly short cap it doesn't prove anything.
Old 31st October 2009, 05:51 PM   #18
Tripmaster's Avatar
OK
Richard
Old 27th November 2009, 02:25 PM   #19
Tripmaster's Avatar
Originally Posted by dangus View Post
So, it sounds like the backlighting inverter. Sometimes those are separate modules that can be replaced easier than repairing them.
Aren't you the man!
I changed the inverter, and hey presto!
Thanks for everyones help
Richard
Old 27th November 2009, 04:08 PM   #20
thermal runaway's Avatar
If that cap had failed it may have taken out other components or be the victim of another fault so unless u can check defined parameters with a meter it's like shooting in the dark really.
Greetings - New Member Checking In Moke Introductions 1 6th August 2008 02:51 PM
Checking ARC SP9 Pathmark Tubes / Valves 2 11th December 2007 05:03 PM
Checking in... ghudnub Introductions 1 19th September 2005 04:58 PM
Checking used capacitor chris ma Everything Else 7 24th June 2003 01:59 AM
Newbie checking in toenail Introductions 6 8th March 2003 02:15 PM
Page generated in 0.11751 seconds (75.10% PHP - 24.90% MySQL) with 10 queries
