| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi all,
Just a quick one. I've Googled for a while for no joy. I'm running a 12v 0.22A brushless DC computer fan to cool a drill charger I built. It's powered from a spare 12v tap on the main transformer, separately rectified with a small integrated bridge rectifier and no filtering, and seems to work fine. It'll be run for up to ten hours straight. Should I be using some smoothing capacitance on the motor circuit? I don't know much about these motors. Cheers Stuey |
#2 |
A smoothing cap might do more harm than good. A transformer winding rated at 12Vac means 12V RMS. When that is rectified and smoothed, it gives around 15V dc. But without smoothing, it remains at 12V RMS - or marginally less - taking the voltage drop of the rectifier into account.
So adding a smoothing cap might also require a voltage dropper resistor to ensure you dont exceed the motor's voltage limit. The motor probably won't mind a rippley Dc at all.
Steerpike's Toybox |
#3 | |
Thanks; I'll leave it. Stu |
#4 |
I'd be kinda concerned that the circuit in the fan might not be so happy with rippley DC,but if it seems to be working,meh. If you decide to add the cap,you can make it a CRC,to drop some voltage and help 'filter' some of the noise from the fan. I've noticed that some fan's put the switching noise back onto the rail,but a (C)RC on the fan usually cures it for me,as well as making the fan run a bit slower and quieter.
Just a thought. |
#5 |
Fan motors are very forgiving of power.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
| Question, about power, audio power into speakers... what happens? | destroyer X | Solid State | 9 | 6th June 2008 08:19 AM |
| New EASY DIY brushless motor | AudioOrigami | Analogue Source | 84 | 28th May 2008 07:09 AM |
| Power amp question | adventfan | Solid State | 3 | 8th December 2007 06:48 PM |
| Op amp power question | speakerguy79 | Parts | 1 | 11th February 2007 11:04 PM |
| Pre/power amp question... | Quattor | Solid State | 9 | 15th July 2003 09:46 PM |
| Page generated in 0.10843 seconds (76.63% PHP - 23.37% MySQL) with 10 queries |
