| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Everyone says to use Y splitters to divide one signal (output) to multiple inputs, but not the other way round. I've seen passive summing circuits using only resistors, but most circuits use an opamp, with all inputs to be summed going to the inverting input. Here's a typical circuit: ![]() Also, the reason Y adaptors are a bad idea is because each source device sees the parallel combination of the destination's input impedance (should be high), and the other source's output impedance (should be low). Thus, the combined impedance is too low, and the source gets distorted. My question - in the above circuit, won't each source still see the other sources in parallel with the opamp's input impedance (which is really high, so it doesn't matter). So is it R1 R2 and R3 that are used to make the effective (paralleled) impedance high enough? So in this diagram, I'd probably want to use 100K or so for each resistor... so then each source sees 100K || 50K? And the gain is of course set by the ratio of R1/R2/R3 to Rf. I have other ways to adjust gain (this is to use a single subwoofer for 2-channel as well as 5.1), so all I'm looking for here is the summing action. One more question - my linestage is a autoformer based passive, so the output impedance at DC is a near short (it's just a long wire). Does that complicate things in any way? If I wanted to sum the left and right channels of my linestage's output (it has 2 sets of outputs), would this cause the other (main) pair of outputs to get shorted and become mono, or something like that? Thanks in advance. Saurav |
#2 |
diyAudio Retiree
The summing juction is a very low impedance. The inverting input is following the non inverting input voltage by the mechanism of the negative feedback of the op amp.
http://www-s.ti.com/sc/psheets/slod006b/slod006b.pdf |
#3 | |
The opamp keeps the summing point at 0 V wrt to local ground reference. Inability to do this constitutes distortion at the output terminal. Eric.
I believe not to believe in any fixed belief system. |
#4 | |
Thanks, that's the point that I was missing. Here's a quote from that op-amp article:
Thanks once again. Saurav |
| Summing Op-Amp circuit | FastEddy | Subwoofers | 42 | 24th April 2007 11:19 PM |
| DCX 2496 question laymans terms (aka ignorant mans terms) | cmckasty | Digital Line Level | 1 | 11th May 2005 03:03 AM |
| Op-amp input impedances and a pot/attenuator | breez | Chip Amps | 5 | 1st February 2005 01:17 PM |
| Input transformers and IC input impedances | duffy | Chip Amps | 4 | 2nd December 2004 06:08 AM |
| line input impedances? | Dominique | Parts | 5 | 5th August 2004 11:19 AM |
| Page generated in 0.08847 seconds (76.97% PHP - 23.03% MySQL) with 10 queries |
