Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th May 2003, 10:17 PM   #1
Default sequential power switching
anybody know were i can find a circuit diagram for a sequential mains switching unit?
im after something that will power up my system in a sequence with a delay between each unit being turned on,and reverse the sequence on turning off.
ive use EMO units in the past but at £450+there a a bit expensive for hippy on a tight budget
Old 18th May 2003, 08:24 PM   #2
Gepetto is offline Gepetto  United States
Send a message via AIM to Gepetto Send a message via MSN to Gepetto
Thumbs up I am working on one now...
I have my boards just back from the fab. It is capable of sequencing 5 SSRs in a delayed fashion with a nominal 1 second delay between each. The delay can be altered. It has an LED indicator for each stage.
I am working on the mechanical design now, a baseplate to mount the components on and serve as the heatsink for the SSRs. I expect I will have the baseplate protos in a couple of weeks.
I am using it in a different mode than you tho. I will have 5 stage soft start seqencing for all my gear using this circuit. You can wire the AC portion in a multiple of ways to achieve your desired output.
It only sequences in the on direction. In the off direction, it turns all units off simultaneously.
It can be triggered either by the AC out on your master preamp/control head unit or by a 12V trigger available on many preamp/control units.
Email me if of further interest.
Joe...
G...
Old 18th May 2003, 08:51 PM   #3
cheers for the offer Gepetto however i realy would like to get the switch off sequence to be a mirror of the start,after a sudden brain wave(unusuall for me) im now thinging along the lines of a bargraph driver (LM 3914) being fed from a ramp genarator,not the most elegant of solutions but on paper at least it apears to work
Old 18th May 2003, 10:36 PM   #4
Default What are you planning on using for trigger?
Just curious what you are going to rely on to start the chain of events (AC on one of your components? 12V trigger? Other?) How many events(delays) are involved?
Thanks.
G...
Old 18th May 2003, 10:51 PM   #5
just a plain old switch
4 at the present,but the lm3919 will allow me to add stage as required upto 10 if needed
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
Need to make sequential power strip digital desire Solid State 1 20th July 2007 01:57 PM
Sequential power-up of amp / preamp cbutterworth Everything Else 1 2nd March 2007 06:00 AM
Sequential soft start PSU ideas chris ma Power Supplies 11 2nd May 2005 08:15 PM
Sequential LED driver. imix500 Parts 15 13th August 2004 02:41 PM
Page generated in 0.07565 seconds (78.24% PHP - 21.76% MySQL) with 10 queries
