Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 14th May 2003, 04:46 PM   #31
mbroker is offline mbroker  United States
mbroker's Avatar
Send a message via ICQ to mbroker Send a message via AIM to mbroker Send a message via Yahoo to mbroker
Rectangular holes: One of those square punches will work on sheet metal, but not on thicker plates. I've only made a couple square holes in aluminum, so YMMV. I drilled a smaller hole in each corner, then used a larger bit to remove the majority of the diameter. Then a file finished it up pretty well. Depending on thickness, I could see a Dremel with appropriate tool doing a pretty good job filing if you only have one or two holes to make, and have a firm, steady hand.
Drill speeds: The current Fastenal catalog has a drill speed chart mixed in with the drill bits section. I'll bet that the cast few catalogs have had the charts, also. Unfortunately, it only lists the SFM, and not material being drilled, and drill bit material. I usually just use about 75% the speed on the chart on my drill, as this seems to work the best for my tools and materials.
The Geek Group
http://www.thegeekgroup.org
Makita Drill TroelsM Equipment & Tools 27 14th September 2007 08:02 AM
To drill or not to drill? (a VPI turntable) m.parigi Analogue Source 5 6th January 2006 03:32 AM
Might need a drill press xyrium Multi-Way 3 22nd June 2005 11:38 AM
Drill sharpening Koy Equipment & Tools 6 1st October 2003 02:57 PM
opa 541 drill patternt for heatsink pundip Chip Amps 2 17th July 2003 07:49 PM
Page generated in 0.05971 seconds (70.50% PHP - 29.50% MySQL) with 11 queries
