Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th August 2009, 01:24 PM   #1
Send a message via MSN to Snickers-is
Default Discrete ring counter
Hello!
I am searching for a semi standard circuit. I want to make this logic function with a high speed discrete circuit:
There are some important key factors to this:
- The sequence must be fail proof. I.E. the out 1-3 and the out 4-6 must allways be in sync.
- The timing is crucial. The pulses 1-3 and the pulses 4-6 must be identical. If the width of the pulses 1-3 is identical to the positive input pulses, the pulses 4-6 must be identical to the negative input pulses.
- The resolution must be at least 100ns.
- The delay must be less than 50ns.
Live sounds better than HiFi.
Old 16th August 2009, 02:08 PM   #2
MaxS is offline MaxS  France
Hello,
For the moment, a quick search gave me this :
http://www.vk2zay.net/article/file/938
I'll run the sim later.
MaxS
Ca marche pas ! Tu ne l' as pas branché non plus ....
Old 16th August 2009, 02:29 PM   #3
Thanks MaxS
I found that one too. I found out that the logic is ok, but the curve shapes are not that good.
Old 16th August 2009, 02:57 PM   #4
Does anyone have an idea why this does not work?
Old 16th August 2009, 04:36 PM   #5
Michael Koster's Avatar
Yes. /SET and /RST inputs on a '74 are inverting inputs and your
reset signal in is holding all the flipflops in the init state. Try inverting
the reset signal, i.e. hold it normally high and pulse it low to reset the
counter.
Your output waveform will switch at 1/2 the frequency you expect.
Can you double the clock? Is it a free-running clock or something
from an encoder?
Can you reveal a little more about the use? Why are you depending
on exactly co-incident edges? There is probably a simpler way to
solve the problem w/o high speed logic...
Michael
Old 16th August 2009, 06:36 PM   #6
Thanks Michael! That solved it, mostly.
I do not want to go too deeply into what this is for.
The logic function is crucial, but it does not have to be done with logic circuits. It can be done with a programmable controller or with transistors too.
Here is another attempt that worked out better, but it behaves a bit strange before it has been reset:
Old 17th August 2009, 11:07 AM   #7
Hello Sirs,
If your application allows you CPLD design, you could design it as a state machine.
I will try if it is possible to simply describe it.
MaxS
Old 17th August 2009, 11:41 PM   #8
Hello MaxS
What is CPLD? A processor of some kind?
Page generated in 0.09568 seconds (76.42% PHP - 23.58% MySQL) with 10 queries
