Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th August 2009, 08:11 PM   #1
wicked1 is offline wicked1  United States
wicked1's Avatar
Default Free speaker wire shootout - cat6 vs romex
I've been using cat6 (bit thicker diameter wire than cat5) for my speaker wire. All solids to positive, all stripes to negative, so the signal was going through the tp's.
I decided to try some romex (in wall solid power cable).
The romex is way better! More bass, and clearer highs.
My setup is a 7ish watt 300b into fostex full rangers. about 20 feet of cable between amp and speakers.
Old 15th August 2009, 09:26 PM   #2
49 - for the 16th time
c2cthomas's Avatar
What gauge Romex are you using? 16??
Nice idea - it won't cost much for me to try this out!
It's solid core wire so you might be on to something with this!!
Now to purchase in bulk - do some cryo treatment - repackage with a snazzy name - and presto!!! Audiophile speaker cables!!
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 15th August 2009, 09:54 PM   #3
Nice, Im using 6 of the cores from 2.5mm2 12 core, XLPE, armoured cable.
Old 15th August 2009, 10:39 PM   #4
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Or- even better - just pretend you have done the cryo treatment....
liquid N is cumbersome to work with... hang on - just maybe -196 C is not enough.... liquid helium? anyone ? maybe argon?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 16th August 2009, 12:59 AM   #5
wicked1's Avatar
It's 20amp power cable. (just because I had a bunch sitting in my garage) Not sure on the gage.
You should try it! why not. There are other posts around about the idea, and also about using cat5. After trying both, solid core power cable is a clear winner! I was really surprised at the difference.
I know it's not ideal, but so far it's the best free speaker wire I've tried.
Old 16th August 2009, 01:22 AM   #6
Theo404 is offline Theo404  United Kingdom
Theo404's Avatar
Default Re: Free speaker wire shootout - cat6 vs romex
Your speakers are 40ft apart?
Old 16th August 2009, 01:28 AM   #7
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Default Re: Re: Free speaker wire shootout - cat6 vs romex
Tall speakers + tall equipment racks can use up a lot of wire.
Old 16th August 2009, 01:29 AM   #8
wicked1's Avatar
No
I thought about clarifying that earlier, and guess I should have. The speakers are 20' apart. The amp is next to one speaker, and the other is across the room. I keep the same cable length on both.
It's not ideal, but that's the way it has to be in this room.
-edit, and yeah, the next poster is right. They are closer to 15' apart, and then add in the distance on each side to go down the table, down the floor past the joists, then across to the other side of the room, back up through the floor and a few more feet to the speaker input.
Old 16th August 2009, 01:44 AM   #9
Theo404's Avatar
Default Re: Re: Re: Free speaker wire shootout - cat6 vs romex
No
Fair enough, was being facetious really
Nice job hiding your cabling, waf/swmbo enforcement?
Are they shielded btw?
Old 16th August 2009, 01:50 AM   #10
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I cannibalized some thick flexible power cords from Home Depot. They have 3 wires, though, so for convenience I connected white and green-yellow together, at least one of wires has a half of resistance.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Page generated in 0.11628 seconds (81.91% PHP - 18.09% MySQL) with 10 queries
