Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 28th August 2009, 09:26 AM   #1
paulspencer's Avatar
Default HELP! PC works here but not there ... electrical problem?
A friend has a dilemma. PC sometimes won't boot up. It just beeps and beeps. I think the problem is with the electrical cables in the unit which is fairly old (they still have fuses not breakers). The PC was working fine, but suddenly it wouldn't boot up and this problem is intermittent.
  • The PC works fine both of 2 other houses where it was tested
  • Another PC in another room in the house works fine
  • When PC isn't working, TV and other electrical items seem to work fine
  • PC has been realiable and without any issues previously
  • Electrician didn't find any problems BUT he came when the PC was working normally! He thinks the line is probably dirty
  • A different PC in a different room works without problems, but on the first instance that PC in question wouldn't boot, this second PC also wouldn't boot.
Does anyone have any suggestions or insight?
Is it possible that there could be an intermittent issue like incorrect voltage that might affect a PC but not other appliances?
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 28th August 2009, 03:42 PM   #2
star882 is offline star882  United States
star882's Avatar
Check for bad capacitors. They might be marginal to the point where it doesn't work at low line voltage.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 28th August 2009, 03:56 PM   #3
EBM_dude's Avatar
I suspect a bad PSU too. Check those PSU's caps IMMEDIATELY! I had intermittend problems with a PC until I replaced the PSU. It's caps were all bloated. Luckily I caught it in time as it was starting to put out much higher voltages...
Old 28th August 2009, 03:58 PM   #4
Well, I've built an amplifier power supply before, but how do I test the PC power supply?
Old 28th August 2009, 04:02 PM   #5
EBM_dude's Avatar
Just watch all the voltages under load. Most BIOSes allow to view the values under "Hardware Config" or something like that. Also, pop up that PSU and take a look at the caps. Please be careful, the line caps can hold up to 400V for a rather ling time!
Old 31st August 2009, 01:29 AM   #6
PB2 is offline PB2  United States
PB2's Avatar
I agree with Star.
Check the caps around the processor on the motherboard for leaking out the tops. See bad caps here:
http://www.badcaps.net/
I'd just replace the power supply if it is more than 5 or 10 years old, if you've checked everything else.
Hard drive could be marginal also, download low level diagnostics and run a surface test, or try Spinrite.
Pete B.
Help needed with Musical Fidelity P270 II electrical problem dynoPort Solid State 12 17th May 2009 11:17 AM
Electrical problem sdedalus Everything Else 1 22nd October 2006 08:39 AM
VOltage regulator works, but theres a problem silentblackhat Solid State 8 15th June 2006 10:36 PM
Page generated in 0.09443 seconds (73.81% PHP - 26.19% MySQL) with 10 queries
