| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#41 |
I had a ton of them from old photo copiers....the pins were a bugger to solder being steel....but hell they are bright
#42 |
i would say yes. theres more base than before. and if i play the same music theres a few sound's i can here. that were not there before
voltage regulater was what was killing the battery.i replaced it with a power resister . i ran it for 3 hours last nite battery is still good meter on the battery pack so i can tell when it's do for charging i cant keep using my bel merit tester. i would say its the amps because its only running at 28.7v yes battery power works
#43 |
i will have a webpage shortly just some finished pic's for the record's
#44 |
#45 |
0
#46 |
How are you doing your ballanced inputs for the GainClones?
#47 |
i would have used rca's but i had non. nothing diferent about it just used 2 pin's instead of 3 for each input. just looks good
| Holy Luck Batman,,, | planet10 | The Lounge | 0 | 22nd January 2009 07:10 AM |
| is a TO3 case better? | Jonny Hotnuts | Car Audio | 30 | 21st March 2008 03:59 AM |
| Holly Days time | Zen Mod | Pass Labs | 3 | 16th December 2007 11:48 PM |
| Holly Grail DAC | Van Hai | Digital Source | 2 | 16th May 2005 04:46 AM |
| What to use for a case ???? | la9 | Chip Amps | 3 | 22nd August 2004 04:34 AM |
| Page generated in 0.07651 seconds (82.18% PHP - 17.82% MySQL) with 11 queries |
