| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#21 |
if anyone has a setup for charging batterys in a amp set me up
thanks..... |
#22 |
hmm gota wire em up the other way to much juice here 120v
total each cell is 12V !!warning!! dont try this at home if you never worked with cells shorting the cell would be a bad thing.cells can explode theres a total of 10 cell at 6 only it comes up 77.7v ouch to much big time. wire the other way would be 12v |
#23 |
hahaha...Karma...great battery pack....if ya need help charging let me know....i think you know enough how to do it...I`m just up the road if you need help
Cheers!!The DIRT® |
#24 |
i tryed it with 2 cells per channnel it does work just tryed it
wow gota make a pcb for a slow charge that way i dont have to time it |
#25 |
you can trickle charge them easy off a small transformer and diode isolate each cell......and ofcourse current limit so they equally get the same charge
#26 |
sounds good. i gota source out some parts im tapped out. to be continued
#27 |
#28 |
batterys finished even has a breaker bonus.i found the original
charger from the ups im going to use a dremal tool to cut the pcb. tested it charges. still gota switch it over to batterys to charger but it works. sunday ill finish it. and time it to see what the battery life is
#29 |
1
#30 |
For $10 I just picked up a switched mode supply for a mainframe (?) rated at 5V 250A ! It is huge, the Vout is a couple of bars an inch wide and several mm thick with a bolt attachment! Could make a nice welder...
Inside it has some pretty massive heatsinks, hefty diode bridge & regulators, and 4x 560uF 450V and 3x 15000uF 7.5V caps. Which incidentally should be nice for my tube amp project, where I need high voltage caps and also low voltage for the heaters. Score! The case is pretty strongly built too, it would have cost a packet back in 1995 when it was new. The 150mm cooling fan will probably end up in my computer, running at low RPM for silent operation. Yay for industrial power supplies! |
| Holy Luck Batman,,, | planet10 | The Lounge | 0 | 22nd January 2009 07:10 AM |
| is a TO3 case better? | Jonny Hotnuts | Car Audio | 30 | 21st March 2008 03:59 AM |
| Holly Days time | Zen Mod | Pass Labs | 3 | 16th December 2007 11:48 PM |
| Holly Grail DAC | Van Hai | Digital Source | 2 | 16th May 2005 04:46 AM |
| What to use for a case ???? | la9 | Chip Amps | 3 | 22nd August 2004 04:34 AM |
| Page generated in 0.10315 seconds (81.60% PHP - 18.40% MySQL) with 11 queries |
