| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hey Guys,
I'm sending audio over Cat5 about 100 feet and picking up a light 60Hz hum. Any ideas on how to reduce this? Right + --> Brown Right - --> White/Brown Left + --> Green Left - --> White/Green Would an "audio balun" help with the hum? If so, can I make one myself? - jason |
#2 |
I've used cat-5 for audio before,but not over 100feet,probably ~50ft max.
Try grounding the other 2 unused pairs,kind of a quasi-shielding. Routing of the cable can be important too,make sure it isn't near any 120V wiring,etc. |
#3 |
try loading up the cables with a resistor as low in value as possible. If the driving end/source can drive 600ohm load then put 600 ohm resistors on each of the pairs at the end of the cables. The lower the overall impeadence the lower the induced hum will be. That's one of the big reasons microphones are low Z
#4 | |
I should add that the source is a sound card, but I am more than willing to buffer it through some sort of buffer circuit to get the hum to go away. Is there any sort of differential pairing that I can do? - jason |
#5 |
First try it with the sending and receiving units in the same room plugged into the same AC power outlet. Still hums try a 2 foot Cat5 cable. Or try a shielded cable. When it works OK with everything together, run a long AC extension cord from the distant room and see if it's still good. PC power supplies like to create ground loops.
Kevin |
#6 | |
- Same room, same outlet, shielded cable: No hum - Same room, same outlet, 2 foot Cat5: No hum - Same room, long extension cord (100 foot), sheilded cable: No hum - Same room, long extension cord, 2 foot Cat5: No hum - Same room, 100 foot Cat5 coiled on ground: No hum - Different rooms, 100 foot Cat5 stretched: No hum - Different rooms, buried Cat5 connecting rooms: HUMMMMMMMM I think it is safe to say that the buried cable is causing the hum. It is near a 240VAC line, so it's most likely picking that up. Are there any sort of "end point buffers" or "differential transceivers" that I can employ to do common mode rejection? - jason |
#7 |
Use a higher signal voltage and use the other two pairs to equalize ground potentials.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#8 |
This makes sense. How do you recommend that I attenuate at the receiving end?
Do you mean simply hook them up to ground so that there is better grounding between source and receiver? - jason |
#9 | |
If possible, decide which side to "hard ground" (tie equipment ground to mains ground) and which side to "soft ground" (parallel RC connection to mains ground) or no local ground at all. Note that the side with soft or no grounding must use a power supply that is double insulated.
#10 | ||
Code:
R1
Line -------^^^------ Receiver +
R2 / / R3
Gnd ---------------- Receiver Gnd (soft)
- jason |
| Line level audio over CAT5 | mpkayeuk | Everything Else | 29 | 27th October 2011 03:37 AM |
| AV IR over Cat5 (simple audio/video repeater for Sky, Digital Tv and Tape recorder) | audiodesign | Solid State | 0 | 24th June 2009 02:28 PM |
| audio/power/control over cat5? | cbriere | Analog Line Level | 4 | 26th November 2007 05:34 PM |
| RCA interconnect with Cat5 ? | gychang | Everything Else | 6 | 30th April 2007 05:08 PM |
| Cat5 | Nappylady | Multi-Way | 27 | 31st March 2003 02:13 PM |
| Page generated in 0.11902 seconds (84.02% PHP - 15.98% MySQL) with 10 queries |
