| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Can e.g a silver anodizied front plate be anodizised in another colour without any other preparation but degreasing or does it have to be sanded first ?
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#2 |
The old finish will need to be completely removed first. Sanding will work, but so will several chemicals.
#3 |
Thanks Steve.
Do you know which chemicals ?
#4 |
The easiest to obtain is sodium hydroxide, or lye. Mix 4 to 6 oz to a gallon of water. Read the warning labels. The solution will get very hot, so do not mix in a glass container, it may break. Plastic is best. You will need good ventilation and NO open flames. Do not leave the piece in the solution too long or it will begin to dissolve and leave the surface rough.
If you plan to have the piece anodized by a commercial facility, let them remove the old surface. |
#5 |
Thanks a lot for your help, Steve
#6 |
Sorry to piggyback onto your thread, Jan, but may I ask Steve an on topic question? I've only just been thinking about this myself.
Steve, if you wish to remove the black anodising of a faceplate with NaOH because you wish to have a silver anodised surface (ie. reverse of Jan), does it need to be re-anodised? Or is there a way to remove the dye and leave it anodised silver; say, if you are very careful about the time limit you leave it in the solution? Thanks Stuey |
#7 |
Stuey
Your'e welcome. I'm interested to
#8 | |
It needs to be anodized again. The dye is in the oxide layer. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#9 |
Thanks Jan!
Magura, I thought as much. I was hoping the dye could be removed without removing the oxide layer. I had some idea it permeated pores in the oxide or something like that and may fade before the oxide is touched. Oh well! Cheers Stuey |
#10 |
Magura is correct. The dye soaks into the very tiny pores in the oxide layer. The layer is then sealed by immersing in boiling water, making the dye permanent.
| Garrard 301 Colour | 405man | Analogue Source | 3 | 24th November 2005 02:51 PM |
| Three-colour LED's / Red + Green | Jan Dupont | Parts | 5 | 23rd December 2003 06:37 AM |
| Page generated in 0.10337 seconds (79.38% PHP - 20.62% MySQL) with 10 queries |
