DIY SMD pic & place from XY plotter DIY SMD pic & place from XY plotter - diyAudio
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 30th July 2009, 03:50 AM   #1
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Default DIY SMD pic & place from XY plotter
I have an old A3 size flatbed plotter that I used to use for pcb artwork many years ago. Now I would like to see if it could be converted to a pick and place machine for surface mount components. Does anyone know if someone has done this before? 99% of the parts I want to mount are 1206 size and it only needs to pick it and hold it in place on the board while I manually solder one end of the part, then I would go around and solder the other ends after it is finished.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 30th July 2009, 04:18 AM   #2
sivrat is offline sivrat  South Africa
about the closest thing I have seen is this:
http://hackedgadgets.com/2007/06/07/...place-machine/
using a taig mill, but it just places the part not hold it while you solder.
the dificulty would be in getting the part centered on the pick up vacuum. if you can sort that, then you will pretty much have it made!
nice idea.
DIY SMD pic & place from XY plotterHide this!Advertise here!
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 20 27th July 2016 07:11 AM
PCB making with plotter? nuppe Everything Else 22 26th April 2009 06:35 AM
HP 3582 FFT Analyzer & Plotter? Hardi Equipment & Tools 0 14th January 2006 03:30 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Copyright ©1999-2017 diyAudio
