Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd July 2009, 11:07 PM   #1
Default Custom mini audio monitor
Hello, First post here.
I work backstage and use Clear Com intercom systems. These are beltpacks with headset with mic/headphones. Many times I'll need to just monitor the com in-case someone needs to contact me. I'll usually position the headphone so it points at me and then turn it up and hope to hear it when needed instead of wear it constantly. They do make base stations (bisquits, bit*h-boxes, whatever) with external speakers but those are pricey and somewhat large. I would like to go kind of renegade and use my own little monitor from my pocket when I need it.
I'm looking to make a small hand-held size box with a speaker/volume knob that takes xlr in and passes the xlr out on to the beltpack.
The clear com belt packs are wired pin1=common, pin2=+30vdc, pin3=intercom
Can I get/make a small amp that uses that 30v dc and powers a really small speaker?
It might be easier to use if the monitor is between the beltpack and headset? I'm not sure of the output from the beltpack.
Any help or ideas are appreciated. Thank you.
Old 23rd July 2009, 12:35 AM   #2
dangus is offline dangus  Canada
An op-amp with booster transistors, run single-supply, might work. I'm tempted to suggest an LM3886, but I won't.
Old 23rd July 2009, 02:17 AM   #3
Hi Dangus, Thanks for the reply.
I've just spent about 5hrs reading the Burning Amp thread started a couple of years ago.
After seeing the work, and reading your reply, I'm in the wrong part of the www. I'm nowhere close to a fanatic after seeing what you people do. (interpretation: english man, english)
I need more hand-holding than you guys should be providing.
Old 24th July 2009, 07:53 AM   #4
Enzo is offline Enzo  United States
Does Clear Com make a walkie talkie style unit that is compatible with your system? Instead of trying to hack into your headset, how about just a different style unit sitting there on speaker? Possible they also already make little accessory speakers you could pin on your shoulder or lapel.
Old 29th July 2009, 05:40 AM   #5
i have the same issue.. but im a sound tech and being foh makes it even worse for speakers. I've wired a signal light for people to use when they want to find me, just a standard red led. then i pick up the cans =)
Audio Nirvana mini-monitor arold19 Full Range 5 4th February 2009 09:46 PM
Need recomendation for a 4in. mini monitor andy2 Multi-Way 3 17th November 2005 12:20 AM
The A4 monitor, best mini monitor? KURT Multi-Way 5 26th April 2005 02:34 PM
Mini-Monitor Project Going On gary f Multi-Way 29 20th March 2004 04:45 AM
Page generated in 0.07135 seconds (82.72% PHP - 17.28% MySQL) with 10 queries
