| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
I need to replace the 1/4 inch stereo phone jack on a pair of AKG K701's and I'm not sure about the wiring. There are four wires in the cable; red, white, yellow, and black, and I'm not sure which terminal each goes too. The "schematic" that I found here: http://www.akg.com/mediendatenbank2/...d5815555d1.pdf
is unfortunately not very helpful to me. Any suggestions? |
#2 |
I've never had a pair apart, but from the posted link the clue is the label that says 'in-phase'. Also both drivers have white connections which suggests that is ground, i.e. common (even if it changes colour to black at some point).
So, the 1/4 jack has three connections known as Tip, Ring and Sleeve, hence it is often known as a TRS jack. Tip is left, ring is right, and sleeve is ground. So I would wire it as follows... Tip (left) yellow Ring (right) red Sleeve (ground) white and black That'll work I am sure. |
#3 |
hello.
i opend the jack of my good old akg.........red=right,yellow=left and the other two are soldered together to ground.............o.k. greetings............... |
#4 |
Bingo! I appreciate the assistance.
| Thread Tools | |
| 4 Pin Amp output to 3 Pin headphone jack? | StrayS2k | Chip Amps | 3 | 17th February 2009 05:46 PM |
| headphone bypass jack | nukaidee | Chip Amps | 9 | 3rd February 2009 08:38 PM |
| which is which in a headphone jack? | jarthel | Parts | 7 | 15th April 2007 09:52 AM |
| adding a headphone jack | Bama Slamma | Solid State | 1 | 13th March 2007 02:36 PM |
| Can I add a headphone jack to BZLS | tomchaoda | Pass Labs | 8 | 30th September 2003 12:58 PM |
| Page generated in 0.15389395 seconds (72.65% PHP - 27.35% MySQL) with 11 queries |
