Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd July 2009, 08:23 PM   #1
Default rpm meter of cars
hi guys
i am searching for a photo that explains how to tab from the distributor of the car in order to make rpm meter but i could not found any thing or a circuit can some body provide me with a photo or an accurate explanation for that topic?
here is a photo for the ignition system of the car
Old 3rd July 2009, 09:45 PM   #2
The connection from the points to the coil will be connected to ground once every engine revolution, by the points closing.
So there will be a 12V "square" wave at this point.
Because of the inductance of the coil there will be a large positive peak when the points open. This is what the "condenser", normally a 0.1uF capacitor is there to suppress, which id does, to a degree.
Depending on what the tacho requires, you need a series R (maybe 50K or so?) from this point (for isolation) to a 5V or 12V zener diode to ground. The voltage across the zener will drive the tacho, but you may need to experiment with the values.
Be careful! There is a huge inductive kick from these things!
Old 3rd July 2009, 10:05 PM   #3
star882 is offline star882  United States
star882's Avatar
Modern cars actually have much more complex ignition systems (essentially high voltage switching power supplies). If there isn't already a tachometer, you can derive it from the crankshaft position sensor or camshaft position sensor. Deriving it from the ignition control circuit might not always work since the ignition might be disabled while coasting in gear.
http://techno-fandom.org/~hobbit/cars/tachack/
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 4th July 2009, 09:07 AM   #4
Iain McNeill's Avatar
if your car is less than 6 yrs old (or so) you most likely have ODB2 interface on your car. Get a cable and CAN decoder board and download the scantool software (or several other useful apps)
This can be read and graphed by a laptop, tablet, PDA in real time. Keep your eyes on the road
Old 6th July 2009, 08:47 AM   #5
dangus is offline dangus  Canada
Take a look at the LM2907/2917 frequency-to-voltage converter chip. The app notes include a tach circuit for point ignition systems.
LM2907
I'm sure you could pick up a usable signal somewhere on a car with electronic ignition, though.
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 11:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 06:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 08:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 12:22 PM
What no old cars ? (Hi everyone !) a31_ford Introductions 2 19th February 2004 08:23 PM
Page generated in 0.09617 seconds (74.06% PHP - 25.94% MySQL) with 11 queries
