| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
So I pulled this nice transformer out of an old amplifer years ago and kept it for a nice project. I've pulled it back out and want to use it now, but I can't remember where I put in 120VAC.
I think I've pretty much nailed down the secondary side, there are 3 pegs, the middle one is a center tap. The solid windings are thick for high current. On the mains side there are 6 pegs. Three of them have thick solid core windings and three are smaller, maybe 18-20AWG? I'm guessing the three smaller ones are where the 120VAC hooks in, but across them (two outer pins) I read about 3.6 ohms resistance (1.8 ohms per side). According to ohms law that is 30amps if I connect 120VAC into that, which doesn't seem right? Do you think this tranny was fed via some current limiting resistors, it seems to be a Panasonic unit, part number "SLT5P291" which comes up on google hits but no schematic. Any ideas? thanks!! P.S. I showed what I think is the secondary in red and the primary in yellow. |
#2 |
It appears that the red is the primary. To check, connect it to 120v through a light bulb. The bulb should not light if the connections are correct. Then check the voltages to verify.
Get OpenOffice.org! |
| Thread Tools | |
| Panasonic EVJ | 454Casull | Parts | 7 | 1st March 2009 02:06 AM |
| WTB Panasonic WM-61A | neilyboy84 | Swap Meet | 3 | 31st January 2007 04:41 PM |
| Panasonic WM-62 or WM-66 instead of WM-61? | NickZ | Multi-Way | 2 | 20th December 2005 02:02 PM |
| Panasonic Pot | AKSA | Parts | 2 | 10th March 2005 10:44 PM |
| Panasonic FCs | jonclancy | Parts | 8 | 17th August 2004 08:30 PM |
| Page generated in 0.13287807 seconds (70.42% PHP - 29.58% MySQL) with 11 queries |
