| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello
After years of hardly any time spent on watching video, I have just purchased a TV panel and am looking for a decent DVD player to go with it. I do not want to set up a surround system. I confess I do not know much about the current bells and whistles of the current production DVD players. The TV is a 720p. I have seen DVD players out there that up-convert the res to 1080P--would these be compatible with my 720P TV? Or is the up-conversion a user adjustable feature? I would appreciate your recommendations or guidance for a decent DVD or DVD-A player in $100-$300 price range. The lower the better! TIA seraph |
#2 |
I have an Oppo DV-980H and I love it. Only $169.00
It will play everything except BluRay. The audio output section is unbeatable at this price level. http://www.oppodigital.com/
surfing the 2nd harmonic ... @@@@ |
#3 |
I have a Panasonic DMR-EZ28K. It has HDMI, digital tuner, recording capabilities, USB, 1394, and quite a few other nice features. There are two modifications I recommend: add a heatsink and rewire the Nixie tube supply to turn off when not in use. Open the cover and epoxy a heatsink to the CPU. Then there is a jumper that needs to be cut and rewired to another jumper to enable the Nixie supply only when the player is on. (I'll get you the details later.) The heatsink mod will improve reliability in hot environments. The Nixie supply mod helps the Nixie tube last longer and saves a little energy. (I actually mostly use that player as a digital tuner to convert a PC LCD monitor into a small HDTV.)
You may want to look at a Blu-ray player instead.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#4 |
depends what your needs are There are many options. ou may wish to look for a player that can play downloadable movies, raw mepgs and/or various media files from still digital camers or movie recorders. In the older? dvd format there are quite a few that can play nearly everything except blueray. there is a chain of stores in Canada that sell refurbished philips players for around $30-40 that can do most of the above. I have a couple and they work well. I haven't seen any advertised blueray players that can play divx, someone please prove me wrong.
A pc with a dvd player/blueray player and a digital/analog tv tuner will work wonders as well. Many inexpensive video cards/motherboards have hdmi/digital output. Check the back of your tv it may have a VGA input. Mine does and that's what I use. |
#5 |
I second the recommendation for the Oppo.
Mobile Sound Science |
#6 |
Thanks very much everyone for the hints and tips...i am much better oriented now
best |
#7 |
The new Oppo is out:
http://www.oppodigital.com/blu-ray-bdp-83/ and it can do almost everything - except make a nice triple espresso. |
| Recommend me a car amp/player and speaker set - Tripath anyone? | Peteruk | Class D | 3 | 1st June 2010 08:13 PM |
| Recommend a decent player for exercise? | peace brainerd | Everything Else | 13 | 1st September 2009 06:13 PM |
| Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. | Spasticteapot | Swap Meet | 0 | 7th October 2006 09:12 PM |
| What do you recommend for first DIY? | Me@Home | Multi-Way | 10 | 23rd June 2002 01:04 AM |
| How many µF do you recommend for this amp? | hugobross | Solid State | 3 | 29th September 2001 01:39 PM |
| Page generated in 0.08968 seconds (77.82% PHP - 22.18% MySQL) with 10 queries |
