Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 30th June 2009, 07:34 AM   #31
Enzo is offline Enzo  United States
My junior tech asked for some help once on a Yamaha casette deck. This casette could record on all four tracks, and came in a package with a small patch bay and a little mixer. I am thinking maybe MT-44? Would only record on two tracks. Tracks 1 and 2. Tracks 3 and 4 recorded on the side of the tape normally reserved for the other direction, but wouldn't work for us. You could still use it for regular stereo casettes too.
I decided we would troubleshoot together. 3 and 4 not recording. Nothing coming out the record amps. Traced that to some sort of controlling part not turning on. Traced that to some control signal absent. FOund the thing that worked that, and found my self step-by-stepping back through the system until I found a photosensor on the transport not turning on. The sensor looked out through the front. SHined a light on it, it worked.
It turns out, that this deck worked as a normal stereo deck unless you put a special adhesive sticker on the blank cassette. The sticker was reflective, and it reflected an LED light back into the photosensor. This turned on the tracks 3 and 4. Without the sticker on your casette, you got only two channels.
We had troubleshot the problem all the way through the unit and out the front.
My tech was wailing that we had wasted a lot of time. I told him, "No, we just demonstrated to ourselves that we know how to troubleshoot." We took the long way, but we got there.
And that explained this mysterious sheet of shiny sticker labels in our Yamaha drawer.
Old 30th June 2009, 08:22 AM   #32
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Originally posted by G.Kleinschmidt
.....................I bought a stud finder..........................
It just beeps continuously whenever I get within two feet of it.
Are you boasting ?
Some sort of sexual innuendo ?
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 30th June 2009, 08:37 AM   #33
Geek's Avatar
Originally posted by poynton
Are you boasting ?
It's a joke as olllld as the dang gadget itself
Old 30th June 2009, 09:20 AM   #34
GK is offline GK  Australia
Soooory.
Old 30th June 2009, 10:56 AM   #35
Netlist is offline Netlist  Belgium
Netlist's Avatar
Years ago, a dead Crown – I believe a Macro-Tech – came in that I was unable to fix.
When it returned from Crown service department, a 1k resistor was replaced and they had included the old, supposedly broken one. I measured the bad resistor but it still measured a perfect 1k.
Later I fixed several other Crowns with the same problem and it was sure not a bad solder joint. Till today I don’t get why replacing a perfectly good resistor did cure that problem.
Old 30th June 2009, 11:02 AM   #36
SY's Avatar
Hugo, a few possibilities:
Tempco
VCR
Resistor going open with heat
I can't think of any weird troubleshooting issues I've had, but I can sure think of quite a few stupid mistakes I've made, followed by hours of wasted work, culminating in a Homer Simpson, "D'oh!" My favorite was the buffer with a gain of two...
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 30th June 2009, 11:21 AM   #37
Netlist's Avatar
Yes, possibly. Unfortunately, I never tested the old ones other than ohmic out of circuit.
Old 30th June 2009, 12:08 PM   #38
Had just finished soldering and wiring up the circuits I designed and layed out for a nuclear bole hole logging tool used for stratigraphy surveys. These consisted of a couple of photomultiplier and neutron tubes along with regulated SMPS HV supplies, pulse amplifiers, threshold detectors and a bank of PIC uC’s for counting/averaging the multiple scintillation channels and serially telemetering the data via the logging line to the surface equipment. I proceeded to power up and test the tool on the workbench with a mild caesium pill to safely raise the background radiation. Everything worked fine except for the baffling occurrence of a huge pulse that would saturate the PMT preamplifiers at seemingly random intervals. Maybe 2 minutes apart or as many as ten. Spent the most part of a day trying to track down the fault, until someone informed me that "those are just cosmic rays".
Another day I fired up a similar tool to start calibrating the threshold detector for the neutron counter, but could not figure out why the counts were so high (should be next to zero with normal background radiation). I suspected oscillation in either the preamplifier or the neutron tubes HV supply, but couldn’t detect any.
After a few wasted hours I suddenly remembered that I had gotten our “neutron bomb” (a paraffin wax filled steel sphere about 1.5 times the diameter of a basket ball, housing/shielding a sealed neutron source in the center) out of the radiation pit the night before, and put it under my bench. I had been resting my feet on it that entire morning.
Old 30th June 2009, 05:01 PM   #39
Pano is offline Pano  United States
Pano's Avatar
Clever!
Say that 3 times fast! (sober doesn't count)
Take the Speaker Voltage Test!
Old 1st July 2009, 12:35 AM   #40
I forgot to mention that the photomultiplier tubes detect gamma radiation by means of each being coupled to a photon-emitting thallium-activated sodium iodide crystal. I’ve heard that these have medicinal properties and have been licking one for a while now.
Greatest circuit ever (or weirdest) kenpeter Tubes / Valves 25 17th May 2009 09:56 PM
Pre amp fault Addolff Parts 4 6th January 2008 02:55 PM
NAD 214 Power Amp Fault Bennyboyph Solid State 3 14th May 2005 03:33 AM
Buffer Fault pete.a Chip Amps 17 8th September 2004 09:10 PM
alpha 5 Fault paulcurrie Digital Source 2 13th February 2004 12:32 PM
Page generated in 0.14446 seconds (74.76% PHP - 25.24% MySQL) with 11 queries
