| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#21 |
A very very large Sunn all tube bass amp that a client reported it had a strange ticking noise. sure enough after a bit a very distinctive pop/tick would happen every few seconds. after hours of troubleshooting everything. I discovered that the tube was arcing through the glass and to the hold down clamp that sits on top of the 6550 output tube that has springs on either side that hold the tube in place. I replaced the tube and the problem went away. I didnt have a tube tester at the time. I would like to have found out if the tube had some sort of internal short or???
The tube still had vacuum. so im not sure what the problem was. but if you turned off the lights you could see the tube arc to the spring clamp! Very strange! |
#22 | |
But, Oh! the power of the Internet. Didn't take long to see it was a common Jeep problem. Faulty crankshaft position sensor. $35 part, 10 minute repar. Happy! OK, no big deal. Fast forward a couple of years. Friend of ours is working for a snobby rich lady who's Jeep won't start, had been cutting out. Our friend asks us "didn't you find a simple fix for this?" Yes we did - and explained it. She tells her rich boss-lady. But the boss is unimpressed. "Is your friend (me) an auto mechanic?" "Well no", says our friend "but he knows a lot about electronics and fixes stuff." Boss-lady sniffs and refuses to consider it. $350 later her Jeep is fixed. They replaced the crankshaft position sensor. We all laughed and laughed. Well, not the snobby rich boss-lady -she didn't laugh.
They know mink where they grow mink, in Wyomink. |
#23 |
#24 |
Ok if we are going to talk about cars.....I had an 84 Cougar that was afraid of the dark! and I am not kidding!
The car would start and run all day long everyday. but at night it would crank and but not fire! took me months to get it figured out. But eventually we learned that there was no fuel pressure and that the car had TWO fuel pumps! one in the tank one one on the frame rail. during the day when it was warm, everything was fine, but at night when it cooled off. the pump on the frame rail would stick! I made a jumper wire for the fuel pump relay as the computer would only let the pump run for 4 seconds then shut off. I would jumper the relay on. lay on the ground and bang on the fuel pump and it would start to run. Get up start the car, take out the jumper wire and everything would be fine. I could drive home, stop at the store etc and as long as the pump didn't cool off it was fine. THAT was a weird problem to figure out! I just kept thinking to myself what in the world would cause the car not to start ONLY at night? |
#25 |
It wasn't a Cougar, it was a Bat!
#26 |
A few years ago, I had a shop selling computers and some second-hand hifi.
I had a cd player, Akai or something similar, that would only play the Eric Clapton disks I had in the shop. I had around 60 disks in total, mainly original with some cd-rs, 3 by Eric. I tried adjusting just about everything before giving up. As a 'joke', I put the player for sale as a special, "CD player with taste !" It sold to a Japanese student. (I even demonstrated the problem) Andy
If it ain't broke, break it !! Then fix it again. It's called DIY. 14-Nov - home for 5 weeks !! |
#27 |
I remember working on a Belles preamp with noise in one channel. We stuck it on the bench, and when we pulled the top off, the noise went away. Replaced the top and the noise returned. I tracked it down to a diode that was light sensitive. Or, afraid of the dark.
#28 |
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/attachment.php?s=&postid=353269&stamp=1079781945 |
#29 |
Well I haven’t managed to fix my weird problem yet. I bought a stud finder from the local hardware store and the thing has proved to be rather useless.
It just beeps continuously whenever I get within two feet of it.
"Only sick music makes money today." --Nietzsche (1844-1900) |
#30 | |
TinTin -- banned in Brooklyn |
| Thread Tools | |
| Greatest circuit ever (or weirdest) | kenpeter | Tubes / Valves | 25 | 17th May 2009 09:56 PM |
| Pre amp fault | Addolff | Parts | 4 | 6th January 2008 02:55 PM |
| NAD 214 Power Amp Fault | Bennyboyph | Solid State | 3 | 14th May 2005 03:33 AM |
| Buffer Fault | pete.a | Chip Amps | 17 | 8th September 2004 09:10 PM |
| alpha 5 Fault | paulcurrie | Digital Source | 2 | 13th February 2004 12:32 PM |
| Page generated in 0.20558810 seconds (83.99% PHP - 16.01% MySQL) with 11 queries |
