Go Back   Home > Forums > General Interest > Everything Else
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 24th June 2009, 04:44 PM   #1
pdul is offline pdul
Default copy a circuitboard!
Does anyone know a good way to copy a circuitboard already filled with soldered components?
I have a preamp project from a magazine from the early 90`s and i want to do it again but the layout is impossible to source nowadays I truly think i have tried all options SOOO
I will be very happy if somebody knows some ropes regarding this
Old 24th June 2009, 05:50 PM   #2
Geek is offline Geek
GlassFET
Geek's Avatar
If it's that jam packed you can't trace the traces, you need to pull some parts....
Not fun.
Cheers!
-= Gregg =-
"Ratings are for transistors...tubes have guidelines"
Hobby and communites - GeeK ZonE
Commercial site - classicvalve.ca
Old 24th June 2009, 09:53 PM   #3
mjf is offline mjf
hello.
do you know what magazine (and preamp) was it?
greetings........
Old 24th June 2009, 10:23 PM   #4
Steerpike's Avatar
I've done a few by photographing the board. Then using CorelDraw to import the photo - re-sze it to actual real-life size, and line draw over the photograph. Once the tracks are drawn, delete the photo. Then neaten up the tracks if required.
Steerpike's Toybox
Old 24th June 2009, 11:35 PM   #5
mwmkravchenko's Avatar
Default If it's from elector I probably have the PSB design
In the dusty rececess of my computer sits the accumulated elektor audio designs. If it's from that magazine your going to be a happy man. If not at least I tried!
Mark
THem that makes no mystakes makes no thing.
Old 25th June 2009, 03:32 PM   #6
unfortunately its not elector
It is from the Danish magazine named High Fidelity and the project is called AIR. A complete nfb design incl. Riaa
Old 25th June 2009, 03:42 PM   #7
It's a bit of work, but you can re-create any circuit if the motivation is high enough.
Write a bill of materials (list of components), select the parts into a schematic tool, draw the connections as found from the existing PCB (just beep them out with a DVM on continuity), import the schematic into a layout tool, place the components (you already have a schema) and draw the connecting traces or filled areas. Bingo! It can be time consuming but it's worse thinking about it than it is actually doing it...
w
Old 25th June 2009, 04:23 PM   #8
Electrons are yellow
peranders's Avatar
I have issues from the 90's, the swedish edition. Can you remember more precisely?
Old 25th June 2009, 06:50 PM   #9
Thanks peranders.
But I have already everything written about the project, schematics, corrections,photocopies from the original magazines, etc. etc. everything but the pcb which was never showed in printing, only on the actual board when you bought it.
Old 25th June 2009, 07:10 PM   #10
I have thought about one simple way to do it, but i dont know if it will work
What about painting the traces with some black color of some kind to increase the contrast and then try a photocopy machine.
How does that sound?
Thread Tools
Quad 606 copy proba55555 Analogue Source 4 25th September 2007 12:58 AM
Cyrus PSX-R copy dubh Solid State 3 7th February 2007 05:59 PM
DAT Copy protection richardsymes Digital Source 16 30th July 2006 06:53 PM
Old Colony Zen circuitboard warning Mike L. Pass Labs 2 12th February 2004 07:11 PM
I need program for making circuitboard partyjups Solid State 8 3rd July 2001 11:10 PM
Page generated in 0.19605803 seconds (80.54% PHP - 19.46% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
