Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 4th August 2009, 10:55 AM   #11
Inch-o is offline Inch-o  Slovenia
Ah...
And I did ordered the IGBTs from Farnell. I used the FGH50N6S2D...
As well replaced the cap at the input of the small psu(4.7uF/450V), put the protection diodes in place(BYV26+P6KE170A), replaced the two 22ohm/10W resistors...
Old 16th October 2009, 01:39 AM   #12
Hey everyone. I'm working on a PMP3000. Here's the schematic of the power supply that I've put together so far: http://jonathon.onthefive.com/temp/pmp3000psu.png
Upon firing it up after replacing a broken fuse holder, I smoked one of the large ceramic resistors at the input (R12). As it was red hot, I assumed there was a short somewhere. Measuring across (+) and (-) at the output of the rectifier, sure enough there was a short (~0 Ohms). I confirmed that IGBTs T3 and T4 are both appear to be shorted from Collector to Emitter.
Is this the same mode of failure you saw in your mixer? How does the small PSU work? And also, can you give more details of the protection diodes? It seems like that would be a good idea to prevent transients from damaging the IGBTs.
My band has practically no money, so fixing this mixer for practically nothing would be fantastic :-)
Thanks a lot,
Jonathon Reinhart
Old 16th October 2009, 03:06 PM   #13
Also, It looks like all of these IGBTs that we've been considering for replacement have built-in reverse-protection diodes. Are these sufficient?
Old 20th February 2010, 05:14 PM   #14
fredy2 is offline fredy2  United States
Default Behringer PMP5000 problem
The usual cause of the power supply failure is a sudden failure of one of the power amp which places a short on the supply.
The ACTUAL cause that starts the problem is insulation breakdown of the circuit trace between the three drain leads of the rear-most amp and the source lead trace of the T20 and T21 pair of MOSFET's.
The resulting breakdown burns the board and the traces and fries the three switching transistors in the power amp.
On one of my units, one of the 18 volt zeners driving the gate and also the 30 milliohm metering resistor was fried. The power supply survived on that one.
The other unit most of the main power supply components were toasted, including the switching regulator IC and the driving transistors and main supply switchers. The same damage was found in the rear-most power amp.
In both cases the circuit board charred cancer had to be ground away and conductors replaced by hard wiring.
Use the series light bulb trick when powering up after repair.
Old 23rd February 2010, 06:28 AM   #15
Audio Junkie
Zero Cool's Avatar
I have been thinking about adding a fuse in front of those large resistors. should there be a failure, the fuse would blow and not kill those resistors.
Can anyone confirm that the PSU will run without the amp plugged into it? it would be nice to be able to test the PSU by itself first.
Zc
Old 23rd February 2010, 07:35 AM   #16
Default PMP5000 information
Yes, the main power supply will run without the power amps connected HOWEVER there are NO bleeder resistors and the caps store a massive charge at 80 volts, and one needs to bleed the charge before connecting the amp!!!
There is so much current initially that fusing the soft start resistors is probably futile.
I just got my second PMP5000 restored and back together today. Here is the diagnosis and the work accomplished:
The rear power amp had an insulation breakdown from the drains of the three switching transistors to the source of the 9640 transistors. (These are in parallel as complement to the single other side switcher transistor)
The circuit board was bubbled and the cancer was ground out with a dremel tool. Clear epoxy was put over the area. The drains of the 9640's were drilled out and the replacement transistor drains were left full length and sleeved.
Since the grinding removed the source tie trace between the 9640's, this was hardwired with hookup wire.
Since the grinding removed ALL the drain connections of the 3 switching transistors, these were hardwired between them. A hardwire connection was also made to the drain of the single transistor to connect it to the toroid inductor lead closest to it.
Next, the 30 milliohm metering resistor on the bottom side was replaced as it had disintegrated.
An 18 volt, 500mw Zener diode (surface mount) was replaced that was shorted. This is part of the gate drive to one of the 9640's.
The amp was powered first at low voltage from current limited supply. It did not work, but since it did not smoke, it was connected to the main supply after bleeding the caps. One can turn the panel at 90 degrees and have the cables from the panel connected to the amps and supply by putting a book or spacer between the supply and the back of the panel. It still did not work.
Surface mounted transistors T12 and T16 were found to be shorted when the 30 mohm resistor opened. These transistors detect excess current in either polarity through the 30 mohm resistor and their collectors "OR" the signal into a latch of cross coupled transistors, which shuts down the drive signal to the switchers in the amp. (there are seperate ones for each side amp)
These two surface mounted transistors were replaced and the dead side of the amp came alive!
My first amp had the power supply destruction to repair and the same failed amp circuit board fireworks. In this second one, the 30 mohm resistor fused and saved the power supply.
In the my first PMP5000, the softstart resistors got cooked because I tried to start the supply before all the baddies were out. The main switching transistors were gone, the drivers of those were gone, the diodes at the gate drive were gone, several small components were gone, and the 8 lead switching control chip for the main supply was gone.
To sum it up, the failure in the rear power amp can do damage to itself and the main power supply when it arcs out. On the first unit I repaired, the 30 mohm resistor did not open and there was NOT much evidence of the arc and short in the rear power amp, but the smoking gun was there right next to the heatsink. It can easily be missed if there was little flame there and one will immediately blow up the freshly repaired power supply if one connects it again without repairing the amp section.
Old 24th February 2010, 04:28 AM   #17
Audio Junkie
Zero Cool's Avatar
I repair amps all day long. my biggest so far was a 10kw crest, I use a 60 watt 120V light bulb to discharge caps. works great. I am very aware to discharge caps. killed an entire bank of output transistors TWICE in one amp long ago...I have never forgotten to discharge caps since! LOL!
Old 24th February 2010, 05:15 AM   #18
Default I have repaired two of them now.
The HCA4001 chip doesn't go.
The original cause is a short of traces on the circuit board near the three switching MOSFETS on the amp near the back of the unit. There are two 9640's in parallel and a 250 on the other side. The burnt "cancer" has to be cut out and traces replaced with hard wiring. The switcher transistors are toast. Sometimes the 30 milliohm resistor is fried. Often the Zeners in the gate circuit of the switchers are damaged.
The gates are CAPACITIVELY coupled and usually the damage does not extend back to the drivers.
IF THE 30 milliohm resistor is damaged then surface mounted transistors T12 and T16 are toast. These transitors are over current detectors that set a latch to kill the switching signal to the power switchers in the amp.
Note that the power supply has no bleeders to discharge the 80 volt supplies, so one must discharge those before connecting the amps back up.
I can give you info how to go about repairing if you need help.
The original cause is inadequate insulation of traces between the drains of the switchers and the sources of the 9640 switchers. The damage will often destroy parts on the main power supply which played no part in the original failure.
The board is multilayer and I believe humidity enters the cut edge of the board and breaks down the VERY thin insulation of the board. (these are multilayer boards.)
Old 24th February 2010, 05:34 AM   #19
Default Brought the second PMP5000 up yesteday
The final part of the repair was transistors T12 and T16 which detect overload current via the 30 milliohm metering resistor and set a latch which disables the swtchdriver chips.
The output switchers are capacitively coupled and damage usually doesn't go backward from the few components around the gate of the power switchers.
The insulation problem of these units near the rear power amp is the problem. It is the original failure. The arcs occur between two layers of this multilayer board. The insulation is unbelievably thin for the voltage peaks it receives. Wipes out a lot of parts and can wipe the main pwer supply as well.
I can coach anybody through restoring these if they need help.
Old 24th February 2010, 02:41 PM   #20
Audio Junkie
Zero Cool's Avatar
Fredy2,
Yup that sounds exactly like what happened to mine. I will have to double check it now. I know the 30mil resistors were dead on the back channel. I did replace that. but i will check the transistors. I know I didn't discover the fault until after i blew up the PSU so i need to dig in and repair the psu again and then dig into the amp.
Thanks for all the info. how about putting together a rebuild document with photo's etc. keep working on the schematics of the PSU and amp boards! MANY of us need them!!! I keep hoping that someone "leaks" some out to the net and we can find them!
Datasheet psu, 0.1v to 50v @1a... redrabbit Power Supplies 6 26th April 2006 02:32 AM
Datasheet Piersma Digital Source 3 29th January 2003 08:49 PM
Page generated in 0.13418 seconds (82.22% PHP - 17.78% MySQL) with 11 queries
