Go Back   Home > Forums > General Interest > Everything Else
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 15th June 2009, 02:54 PM   #1
coldcathode's Avatar
Default FM antenna
Anyone know of a cheap DIY FM antenna to go in a garage attic?
I have a workshop in my garage and I have very poor FM reception. I would like to construct something cheap to put up in the attic to improve my reception between 88 and 108
Any ideas?
Old 15th June 2009, 03:03 PM   #2
scott wurcer's Avatar
The college radio guys pass this one around...
http://www.wryr.org/Antenna_instructions.pdf
"All of us have a place in history. Mine is clouds."
Old 15th June 2009, 03:14 PM   #3
Scott,
Have you built this?
Is best reception parallel or perpendicular to the loop?
Which corner does the other 300 ohm lead attach to? The directions only mention "adjacent" corner? I am assuming one of the two corners nearest the merge?
Like attached?
Old 15th June 2009, 03:30 PM   #4
Sorry, I did not need it since a simple dipole up high enough worked for me. If you want to try it I would first follow the picture they have. I know the words and the figure don't exactly line up, I also found it a little confusing. Possibly the AARL handbook has a description of the quad principle. 3-6dB extra from a few feet of wire seemed like a good deal at the time.
Old 15th June 2009, 03:42 PM   #5
infinia is offline infinia
infinia's Avatar
Here is another quad optimized for lower FM band
http://www.ham-radio.com/k6sti/cpquad.htm
a little more complicated with more directional gain
don't forget the balun
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 16th June 2009, 10:07 AM   #6
Send a message via AIM to DigitalJunkie
A J-pole antenna might be a bit tall for an attic,but I used one just stuck into the dirt,in a flowerbed.It was piped in to my Sansui TU-717,and I could hear all kinds of stuff!
Just one suggestion,for those who have the space.
Old 16th June 2009, 06:20 PM   #7
Geek is offline Geek
GlassFET
Geek's Avatar
X2 what DigitalJunkie said. Here's some math:
http://www.hamuniverse.com/jpole.html
Another, if you need even more gain, is the colinear. A little more complex to build, but can approach 9dB gain - from an omni vertical.
Cheers!
-= Gregg =-
"Ratings are for transistors...tubes have guidelines"
Hobby and communites - GeeK ZonE
Commercial site - classicvalve.ca
diyAudio Blog - GeeK's Bench
Thread Tools
car antenna coki Car Audio 3 11th August 2007 12:35 PM
DIY antenna Fry-kun Analog Line Level 3 24th May 2007 09:52 PM
FM Antenna jaya000 Car Audio 5 27th January 2007 05:40 AM
Antenna ? fortuosity Everything Else 1 17th October 2005 11:14 AM
What do you think about this antenna ? darkm4n Parts 0 6th March 2004 10:47 PM
Page generated in 0.26977301 seconds (43.96% PHP - 56.04% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
