Go Back   Home > Forums > General Interest > Everything Else
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 9th June 2009, 12:57 AM   #1
FSHZ:42 is offline FSHZ:42
FSHZ:42's Avatar
Default Advice for making interconnects
Looking for some feedback from the DIY'ers on this forum who have built rca type interconnects. I would like to make a pair, but would first like see some of the suggestions/comments on this. Maybe some off the DIY community that have made some rca interconnects could describe what brand of wire and rca connectors, solder, etc, that were used, and also if they made a great detail in sound improvement. Any comments and suggestions would be appreciated!
Thanks,
Emile
Old 9th June 2009, 02:00 AM   #2
http://www.bluejeanscable.com/
Worth a read
Old 10th June 2009, 02:17 AM   #3
TerryO is offline TerryO
TerryO's Avatar
I've had good luck with diycable products. Kevin has all the different wires, terminals, etc., that you'll probably need for any of the popular designs.
www.diycable.com
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 10th June 2009, 04:49 AM   #4
FSHZ:42's Avatar
Hi 454 Casull and Terry O, and thanks for that information! I have tried a few different rca interconnects and wanting to know if the really expensive ones like the Crescendo's make a big difference in sound. I know that this has probably been covered before, but what really makes the difference. I was looking at the Furutech interconnect cable on the Sonic Craft web site and they have the FA-13S for $9.29/ft- then there is the FA-220 for $13/ft. The FA-13S appears to be a solid core wire, while the Fa-220 has an 80 wire strand 14AWG. I went to the Furutech website and found that this FA-220 cable is listed under the Car Audio section. Not saying that there is anything wrong with where it is listed, but how would these 2 cables compare to other cables costing hundreds of dollars more? Is the cable listed on www.diycable.com and http://www.bluejeanscable.com/
the same quality and sound? Maybe one of you guys could help me out with this dilemma. Thanks again for your time!
Emile
Old 10th June 2009, 05:53 AM   #5
TerryO's Avatar
Emile
Emile,
I don't what your system consists of, but unless you have components capable of extreamly high resolution I really doubt if you'll hear any difference at all. I've listened to a lot of high-end gear and remain convinced that cables (if properly constructed) make very little, if any, sonic difference. I've listened to some of the top systems in the world, as well as a number of ABX trials and don't believe that I can hear a difference.
It may be that my hearing isn't good enough and that's certainly possible, but in all the tests that I've witnessed, my ability statistically is no better or worse than the others that were involved.
My advice is to buy decent cables and no more, as there are usually other areas that will make a "much greater" impact on the sonic quality of your system.
Areas to concentrate on are, in no particlar order:
1. Source
2. Speakers
3. Room Acoustics
The real value in the higher grade of cables that are sold is, IMHO, that with quality termination, a set of custom cables can be plugged and unplugged thousands of times, and won't break, degrade or lose contact when used. I tend to swap gear quite often so the extra cost is worth the peace of mind knowing that I have a reliable set of cables.
Others may disagree and that's fine, but I wouldn't spend a lot of money on ICs when there are so many other things that have a greater influence on the music.
Best Regards,
TerryO
Old 10th June 2009, 03:16 PM   #6
AndrewT is offline AndrewT
I have an hypothesis and no real proof.
The quality of the cable has less effect when both the source and the receiver are properly designed to send and receive signals.
When either or both of these components are badly designed for the send and receive function then one will find that cables start to have an effect.
Further, it is not the cable that sounds different. It is the badly designed interface that sounds/measures different depending on the load that the cable adds.
The solution is to ensure that all your sources have an appropriate cable driving ability for the signal they export and that all your receivers have an appropriate impedance and filtering for the signals they are intended to send on.
When the interfaces are properly implemented then plain pairs of copper wires/cables have no audible influence on the signal quality.
regards Andrew T.
Old 10th June 2009, 08:05 PM   #7
FSHZ:42's Avatar
So in other words these two rca cables would sound the same?
http://www.parts-express.com/pe/show...number=240-020
http://www.parts-express.com/pe/show...number=186-162
Thanks,
Emile
Old 10th June 2009, 08:23 PM   #8
Shoog's Avatar
So in other words these two rca cables would sound the same? http://www.parts-express.com/pe/sho...tnumber=240-020 http://www.parts-express.com/pe/sho...tnumber=186-162 Thanks, Emile
The point is - if you have a grunty enough driver and a high enough input impedance - then I would say that they will sound almost the same even though one is rubbish.
Very few components will have those requirements so the cheap one will sound worse in most systems.
My formula for decent cheap cables is - I use gold plated RCA plugs (£3.50 a pair) which firmly grip the socket and Shark cable( http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15 ) which is double screened. About £7.00 a meter pair.
If your hearing big differences then you need a component upgrades rather than waisting money on cables. I used to have a Musical Fidelity X10D which was an impedance matching component. Basically it used a ECC88 to buffer the signal from your component to the amp. It worked wonderfully and improved the overall clarity - how did it achieve this - simply by using the supper high impedance input of a valve to unload the CD players output.
Shoog
I don't believe anything, but I have many suspicions.
Robert Anton Wilson
Thread Tools
help please with interconnects! shepperd Parts 11 13th November 2006 06:09 PM
interconnects tenderland Tubes / Valves 8 3rd June 2005 03:00 AM
Making speakers cables and interconnects from foil inductors JCoffey Everything Else 4 5th February 2005 01:05 AM
Need advice with making an electric violin... :) SkinnyBoy Musical Instruments 35 21st November 2004 08:16 AM
DIY Interconnects ralph-bway Everything Else 0 17th August 2003 10:07 PM
Page generated in 0.22367096 seconds (85.83% PHP - 14.17% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
